Map Sensor connector not there, please help
Old Apr 25, 2022 | 05:18 AM
strafelul's Avatar
Default Map Sensor connector not there, please help
So I bought an 1997 Acura Integra, with an LS/Vtec and a turbo kit on it, i realized afterwards that the map sensor wasn’t plugged in, and i upgraded to a 4 bar because i planned on getting it tuned. Now, I went to plug it in but the connector for the Map sensor is nowhere to be seen. I ordered the pigtail for my map sensor on ebay and my question is, how would i go about to install the connector. Like do it install it somewhere into the harness or straight to the ecu?
Old Apr 25, 2022 | 08:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Map Sensor connector not there, please help
The MAP sensor wires should come out of the engine wiring harness a few inches below the TPS plug. If the MAP sensor plug is chopped off, you will find the original wires there. It is possible that the previous owner used a GM 3-BAR MAP sensor and it would NOT be mounted in the original MAP sensor location on the top of the throttle body... likely close on the firewall with a vacuum line connected between it and the intake manifold plenum. If you didn't have some type of MAP sensor connected, the car would barely idle and usually run really rough.
oksblue
Mar 31, 2013 03:59 PM
methos713
Jun 11, 2007 12:43 PM
JMinSi2000
Jul 29, 2004 08:47 AM
1.8T_EG
May 12, 2003 09:58 PM
ketchup_gsr
Nov 9, 2002 01:02 PM
