idle issue
Old Apr 17, 2007 | 02:39 PM
efyou's Avatar
Default idle issue
okay well first off let me say that its not the crazy honda 1k-2k idle that everyone else seems to have problems with
i could just be needing a tune up but my idle is never constant at all...or is that normal?
like if i started my car to warm and i didnt go anywhere, hit brakes or anything...itll range from 700-900ish i guess, and it feels like its lacking power when i do drive it...any suggestions? also it takes forever to warm up too, (92 LS)
Old Apr 17, 2007 | 03:12 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Default Re: idle issue (efyou)
The reason your car isnt warming up may be that you have a stuck open thermostat. Id need more details about the idle thing. Your idle will adjust obviously whether its a cold or hot start but is it varying from low to high?
Old Apr 18, 2007 | 07:21 AM
super china china's Avatar
Default Re: idle issue (ForceFed_Motorsports)
i also have a problem with my 90 teg idiling between 600 and 1k
Old Apr 18, 2007 | 09:04 AM
Default Re: idle issue (super china china)
Usually varying idle like that is caused by a small vacuum leak... a large vacuum leak will cause a high idle. Hard to say though.
Old Apr 18, 2007 | 03:38 PM
efyou's Avatar
it'll normally idle up to about 1.8k at start up, and then gradually idle down like normal but its not a constant rpm, it fluxuates like 100 rpm up or down
Old Apr 18, 2007 | 04:33 PM
jorge59la's Avatar
you should try a tune up. also check for vacuum leaks your idle shouldn't be that high even at start up
Old Apr 18, 2007 | 06:00 PM
Default Re: idle issue (jorge59la)
My idle is up around 1500rpms and a bit more sometimes depending on weather conditions, but i wouldnt worry bout it. Id to a check for vacuum leaks first though. If stuff like your plugs, wires, cap n rotor dont have a lot of miles on them, then i wouldnt bother replacing them cuz i doubts it the issue.
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
90_Si
26
Jan 22, 2008 06:38 PM
REDMAN1322
Sep 1, 2001 01:29 PM
