I just have to share some of my new goodies....
- Summit Racing battery box, and wiring kit. I am going to relocate it to the passenger side spare tire spot.
- Civic half size radiator and Perma Cool radiator fan rated at 1600CFM. This will allow me to mount the big ol T3/T4 with the compressor on the drivers side.
- Apexi Filter. The best filter money can buy. Period. It is also sized nicely to the room availible, and will be attached straight to the compressors inlet.
- JimFab.com cross member.
Enjoy...
Enjoy...
Re: I just have to share some of my new goodies.... (Bryson)
Looks good. Nothing like a slew of new parts for your car. Does the Jimfab crossmember let you bolt the half-rad straight in?
Re: I just have to share some of my new goodies.... (91CivicSi)
no.
It gives room for it to be mounted lower (because the rad it self is taller then the CRX/civic rad). The stock Cross member is in the way of the radiator, and would need to be hacked up for it fit.
You also need to fab up the rad mounts for it to fit.
Pretty!! I like your Jim Fab, mine is Gray like the pre-production pics that were floating around. I just wish it was adjustable like Z10....
When you are doing your Radiator mounts you should be able to put it just right. If I had modded mine I would have made the brackets an L shape to get the radiator even lower. My install was pretty nasty, plus it is a Fluidyne.
How much for the Apex?
Re: I just have to share some of my new goodies.... (Doodoo)
The Apexi was 80 including shipping from Options Auto Salon.
I will be installing the crossmember this weekend. Because this is not my daily driver, I have no idea when the rest of the stuff will be installed however.
I don't know if your remeber this one from the CRX forum. But here is my install.
https://honda-tech.com/zerothread?id=324468
Damn....Mine doesn't have the mounts for the rad....
Oh well, It looks like It took a lot of work to get it to fit anyway's. I will not have a problem with just making custom mounts.
Looks like your on track, but that relocation kit doesnt look nhra approved, you need a moroso, I believe.
Re: I just have to share some of my new goodies.... (reXem)
Maybe you should look into the Neon rad....seems easier to install
Re: I just have to share some of my new goodies.... (a z n t a k)
I got the rad fan from Summit. Was like 85ish...? It's a 12" fan.
I paid 90ish for the summit box and 30ish for the summit wiring kit (1g).
[Modified by Bryson, 9:55 PM 1/26/2003]
amy
06-11-2006 04:26 PM
yee SERIOUS
Northwest (Sales)
09-12-2005 01:57 PM
