Installing Quaife differential
Old Jan 26, 2003 | 05:09 PM
V-SPEC 1's Avatar
Default Installing Quaife differential
I want to know how hard installing this diff in a b series tranny. To all the experience people in here that done this, please I need to know what exactly needs to be done. Thank you in advance. It's more likely in a gsr tranny.
Old Jan 26, 2003 | 05:35 PM
niedejb's Avatar
Default Re: Installing Quaife differential (boostedb20vtec)
You have to:
Split the tranny.
Pull the speedo gear off the old differential (requires a gear puller) and heat it to put it on the new one.
Pull the bearings off both sides of the diff (couldnt find a gear/bearing puller that would fit so I bought new ones ~ $60)
Shim the new bearings to 12-23 lb/ft resistance with the case halves closed.
Not for the weak at heart.
Old Jan 26, 2003 | 05:43 PM
Farnsrocket's Avatar
Default Re: Installing Quaife differential (niedejb)
that's it pretty much....I have some pics if you want to see.
Old Jan 26, 2003 | 05:48 PM
V-SPEC 1's Avatar
Default Re: Installing Quaife differential (Farnsrocket)
Yes please. I would like to see some pics if you don't mind. Thanks.
Old Jan 26, 2003 | 06:04 PM
niedejb's Avatar
Search on quaife install and choose archived.
Arturbo has all the pics linked you could ever want
Old Jan 26, 2003 | 06:10 PM
Lightning Orders's Avatar
i just got finished installing mine and it was a very big pain. also here is a tip when removing the speedo drive gear make sure not to dent or chip the gear when removing it. i did and had to spend hours fileing down the rough spots to fix it(and you cant just buy the gear you must buy the carrier from acura witch comes with the gear. this has been the first time i have taken a honda tranny apart and everything went very well. just make sure to take your time and watch for falling ball bearings.
1320london
Transmission & Drivetrain
18
Mar 15, 2014 02:40 PM
WVTURBOCRX
Aug 25, 2007 10:13 PM
jdmciviceg
Feb 2, 2002 11:25 AM
