Uh oh, injector problem
Old Jan 23, 2003 | 05:49 PM
Smashback's Avatar
Default Uh oh, injector problem
I just opened my DSM 450s today after having them cleaned and all that jazz, and one of those plastic caps on the end opposite the connector is cracked and the thing is close to falling off. Those are supposed to stay on when you install them, right? I mean they're not just to protect them during shipping or anything? Can't remember, been a while since I looked at my injectors
Old Jan 23, 2003 | 06:35 PM
MiraiZ's Avatar
Default Re: Uh oh, injector problem (Hatchblack)
I hope you don't mean the little caps (like plastic thimbles)
Old Jan 23, 2003 | 06:49 PM
Farnsrocket's Avatar
Default Re: Uh oh, injector problem (MiraiZ)
You don't mean this thing do ya??
If that's what ya mean, then no, don't use it.
Old Jan 23, 2003 | 07:04 PM
Smashback's Avatar
Default Re: Uh oh, injector problem (Farnsrocket)
here's what I'm talking about:
Old Jan 23, 2003 | 07:06 PM
Sleepin''s Avatar
Looks like it's just there for protection during shipping to me.
Old Jan 23, 2003 | 07:18 PM
Default Re: Uh oh, injector problem (Sleepin')
Sorry man, the cap on your injectors look like they are more part of the injector than the one I showed ya.
Does the cap come off easily? I have never dealt with a DSM injector......someone has to know.
Old Jan 23, 2003 | 07:29 PM
MiraiZ's Avatar
Hmmm...I'd look look for a new injector...try to see if you can get a single or maybe take it to Mitsubishi to see if there is a replacement cap for that....it may affect the spray pattern without it
Old Jan 23, 2003 | 07:37 PM
Smashback's Avatar
Yeah, they come off pretty easy. If they are part of the injector, they were replaced by Mike when he cleaned them because I think I remember them being there, but they were gray or something. Well this sucks ***...at least I noticed today instead of when I was ready to install them.
Old Jan 23, 2003 | 08:15 PM
BudaKai's Avatar
That's what controls the actual spray diameter if it's like the ford injectors. Ford's are swappable so you can change the size of your spray pattern.
Old Jan 23, 2003 | 10:39 PM
asianspeed's Avatar
Default Re: Uh oh, injector problem (tzsir)
that's just the pintle caps..and they're there for protection only. It doesn't have anything to do with the spray pattern. And it's fine to use them. Just remove the caps so they dont' fall into the engine.
Old Jan 23, 2003 | 10:51 PM
Flamenco-T's Avatar
how So ?
explain your THEORY please ?
[Modified by Flamenco-T, 1:52 AM 1/24/2003]
Old Jan 23, 2003 | 10:57 PM
BudaKai's Avatar
Default Re: Uh oh, injector problem (Flamenco-T)
Not a theory it's how they are assembled.
You can change the ends on the injectors to control whether you have single wide spray; dual narrow spray; etc... The parts inter-change on them.
How do you think they balance and blueprint them? It's not some black art that only the "RC" magicians can procure.
Take that Stan
Old Jan 23, 2003 | 11:10 PM
Flamenco-T's Avatar
Take that Stan
take that ? oooh boy....
the design of a pintle tip control the shape of the actual spray pattern genius...that plastic cover is just to protect the pintle tip itself
stan
Old Jan 23, 2003 | 11:16 PM
lazerus's Avatar
Haha. 0wn3d.
i wondered the same thing when i first broke one off.. hooked it up to a fuel line, applied some pressure.. man that sucked. fuel didn't have much of a spray pattern. lol.
Old Jan 24, 2003 | 12:12 AM
Bongnak's Avatar
Default Re: Uh oh, injector problem (lazerus)
sooo... hatchblacks injectors or ok once he removes the cap right???
Old Jan 24, 2003 | 08:02 AM
Smashback's Avatar
Default Re: Uh oh, injector problem (Bongnak)
Yeah, I'm still wondering. Should I take them all off or find a replacement cap for this injector??
Old Jan 24, 2003 | 08:17 AM
TurbothisLS's Avatar
it's called a pintle cap as someone stated earlier.
just replace that one, it's not expensive
mike will send you a new one for like $1 if i remember correctly, or just go to a mitsubishi dealer and ask for one
Old Jan 24, 2003 | 01:25 PM
BudaKai's Avatar
Default Re: Uh oh, injector problem (TurbothisLS)
Not really Ow3ned children. I was describing how the Ford injectors I have are not how his are. Mine don't have that little plastic tip they have an aluminum tip shaped the same way except it's actually attached farther up the injector. Reda my post dick you'd see I was making a suggestion. No need to be an Azz-hole.
Old Jan 24, 2003 | 05:37 PM
forcedaccord95's Avatar
I have the same injectors! Mine did the same thing. Mine are in the car and have been for 6 month. I have had no problems. That caps do not effect the spray like the other member mentioned!
Old Jan 24, 2003 | 05:43 PM
sweet's Avatar
Default Re: Uh oh, injector problem (forcedaccord95)
that happened to some of my injectors in the past, the pintle cap/spray thing cracked. i just got my those injectors back from Mike Palm. he not only cleaned them but replaced the 2 broken caps too.
i don't think he's doing any more cleaning for awhile but he may be able to get you the caps if you can't find them anywhere else.
Old Jan 24, 2003 | 06:00 PM
ekb18c's Avatar
I broke that cap once and the injector worked fine. So no need to worry.
[Modified by ekb18c, 7:00 PM 1/24/2003]
Old Jan 24, 2003 | 06:10 PM
sweet's Avatar
Default Re: Uh oh, injector problem (ekb18c)
oh yeah i also used the set of injectors with a broken cap and there were no signs of any problems. but you still wanna be careful.
wickedplastikman
Mar 9, 2010 09:31 PM
HondaHeddie
Nov 26, 2008 10:44 AM
alfee
May 19, 2005 11:57 PM
GReddy SI
Apr 24, 2004 11:17 AM
10seceg
Jan 1, 2004 02:46 PM
