GReddy Turbo Timer Help
Old Jan 24, 2003 | 01:18 PM
Sivik's Avatar
Default GReddy Turbo Timer Help
Hey guys,
I'm having a few problems with my timer. For the most part everything works ok, but some things I can't get right:
1) I can't calibrate my RPM's so it matches the tach. Whats up with that? I've tried many times. Any help?
2) About 90% of the time, when I shut off my ignition, the timer works. The other part the timer shuts off right away and so does my engine. I checked the wires and everything seems to be hooked up right. Any help?
3) I know this has been asked before, but how can I wire it so that my alarm activates when the timer shuts off?
4) I have the speedo calibrated to mph, even though it reads km/h. I tried the kilo but no luck. Always off. Anyone able to calibrate to km/h or do I have to stick with mph? I think it has something to do with the mph being the primary unit for speed on the cluster.
Ok thats all for now. Thanks!
Old Jan 25, 2003 | 07:48 PM
boosted98's Avatar
Default Re: GReddy Turbo Timer Help (Sivik)
hey man i have a 98 also and hooked mine up this past weekend a havent had any problems. The rpm mode is wierd though. Do u have a greddy timer?
Old Jan 25, 2003 | 07:50 PM
TurbothisLS's Avatar
Default Re: GReddy Turbo Timer Help (boosted98)
search for alarm and turbo timer
it will come up with hits on using both
there should be a wiring diagram showing you how to hook up the relay
Old Jan 25, 2003 | 11:51 PM
Sivik's Avatar
yea i have the greddy timer. i can't get the rpms to match at all. did you match the speedo to km/h or mph?
b16excoupe
May 19, 2013 05:57 AM
bitbystreetracin
Honda S2000
Apr 30, 2009 02:24 PM
zebt66
Feb 21, 2005 08:21 AM
abmerop18
Jan 13, 2005 04:20 AM
Ray
Jul 2, 2001 04:01 AM
