TB ...whats to big?
Old Jan 24, 2003 | 12:38 PM
TurBoTeG's Avatar
Default TB ...whats to big?
Im curious to know if there is really sucha a thing as "too big" for a throttle body when boosting. I was looking into a 70mm bbk, or porting my oem one to 64mm. I was told that you actually loose boost if you go to big..is this true? Any info would be great..
Old Jan 24, 2003 | 01:11 PM
Smashback's Avatar
Default Re: TB ...whats to big? (TurBoTeG)
I don't think you'll lose boost
If you do too large you may be doggy on the bottom end though. BBK SUCKS! Mine stuck all day long and so have many others I've seen. Pick a different one....I've heard good things about these:
http://www.ericksracing.com/throttlebody.htm
Speaking of throttle bodies, has anybody used the STR one? Looks like a copy of Erick's.
[Modified by Hatchblack, 10:15 PM 1/24/2003]
Old Jan 24, 2003 | 02:03 PM
CM-R's Avatar
Default Re: TB ...whats to big? (Hatchblack)
how much hp do you gain with a 70 mm tb??
Old Jan 24, 2003 | 02:04 PM
BudaKai's Avatar
You'll just experience lag, but you'll get very nice top-end. Make sure to match your TB with your IM. Not HP torque. It'll move your torque up the RPM range. You might see better HP, but it's just the torque increase up top.
BBK has a bad rap like what blackhatch said.
I've also heard nothing but goods things about the Ericks racing ones, but you could always just get an OEM one from somewhere else as long as they use the speed density system. I'm going to be trying an Infiniti 90mm with 85mm internal diameter when I get the fundings. I can't wait to get a new job. Tired of being broke.
[Modified by tzsir, 5:05 PM 1/24/2003]
Old Jan 24, 2003 | 02:13 PM
swrdply400mrelay's Avatar
I bought a BBK one because it was used and cheap. Personally I haven't had a problem with it sticking, but I have heard other people with that problem. The only problem with it is my idle is now at 1500 rpm's. I'm going to have to wait for Hondata to try and lower it, but I'm used to the high idle now.
Old Jan 24, 2003 | 02:21 PM
Smashback's Avatar
Default Re: TB ...whats to big? (swrdply400mrelay)
It's sticking....that's why it idles so high lol. They all are apparently like that. I fought with it for like 6 months before I finally tossed it back on the shelf.
Old Jan 24, 2003 | 02:23 PM
Farnsrocket's Avatar
Send yours to Proflowdesign.com and have them port it out. They took my GSR TB and bored it to 64mm for like $130 shipped. EXCELLENT work!!!! Once they received it, it took them (no lie) one day and it was in the mail the next day. If they have your TB in stock, they will send you that TB and then you send them yours, for a core, once you receive theirs. Very good service! They use a SS plate that basically looks like a mirror!! Oh, and notice the two screws on the shaft are flat to resist airflow!
Before front
Before back
After front
After back
[Modified by Farnsrocket, 3:30 PM 1/24/2003]
Old Jan 24, 2003 | 02:25 PM
Smashback's Avatar
Default Re: TB ...whats to big? (Farnsrocket)
damn that puppy looks good
It's easier to make Honda parts better than it is to make better parts than Honda.
I think I just made a famous line!!!!!!
[Modified by Hatchblack, 11:36 PM 1/24/2003]
Old Jan 24, 2003 | 02:29 PM
Ha, ha, good line!!! Thanks!
Old Jan 24, 2003 | 02:32 PM
Tofurky's Avatar
regarding the ericks racing; from what i've seen it's effect isn't the greatest unless you have a higher compression/larger displacement motor.... so 1.6ers might not enjoy it too much.
Old Jan 24, 2003 | 02:47 PM
BudaKai's Avatar
Default Re: TB ...whats to big? (Ruckus138)
Very nice. I like. Have you put it on yet? Is there a difference?
Old Jan 24, 2003 | 02:51 PM
Default Re: TB ...whats to big? (tzsir)
Thanks! It's on, but it went on with a hundred other things including my turbo so I really don't have a base line to go from.
Old Jan 24, 2003 | 02:57 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
I heard that if your TB is "too" big, lag will be your only foe, which will be to a minmum. and yes, BBK's suck, and they stick like a ****, get a spring, and you will be alright, or, my suggestion, by another brand
Old Jan 24, 2003 | 03:13 PM
98civicEX's Avatar
portflow.com was EXACTLY what i've been looking for....good info fransrocket!!!
Old Jan 24, 2003 | 04:14 PM
boosted hybrid's Avatar
Default Re: TB ...whats to big? (98civicEX)
Stock works well for me. I dont think that there is a significant gain from going with a larger throttle body, hence why i keep it stock. 5-10whp gain for 300-400.00 is not something I would even consider. Well see if i can make my 400whp on pump gas goal with the stock one, and 500whp on race gas. Just like the stock fuel lines, I think that the aftermarket throttle bodies are overkill and you can make very good power without one.
Old Jan 26, 2003 | 04:55 AM
Default Re: TB ...whats to big? (boosted hybrid)
No problem!
Old Jan 26, 2003 | 05:42 AM
TheShocker's Avatar
I'm sending my TB to those guys this week. I'm excited.
Old Jan 26, 2003 | 05:45 AM
BudaKai's Avatar
I look more to loosen up the air flow and bring the temps down a bit by reducing turbulance. The lag as you stated is easily countered with higher compression or a faster spooing turbo. Not to mention the throttle response isn't that bad from what I've been told. In the end we'll see. When I get mine all together again I'll let you know what the difference is like. It's taking forever being broke.
Old Jan 26, 2003 | 05:53 AM
ekb18c's Avatar
With BBK TB's , sometimes you get lucky and sometimes you get stuck with the ones that stick.
I was lucky! The first one I purchase didn't stick. However i have seen other people go through 2 or 3 of them before they are good.
Old Jan 26, 2003 | 06:20 AM
Default Re: TB ...whats to big? (ekb18c)
Here's the info and contact for Proflow Design. My bad, it's $155 shipped....still a damn good deal! Jim is a really nice guy! Very personable and professional.
ProFlow Design
Attn: Core
14600 157th Place S.E.
Renton, WA 98059
Proflowdesign@hotmail.com
Jim Hill
Old Jan 26, 2003 | 08:16 AM
TREVER's Avatar
looks nice
but I would be really scared of that thing caving in, it's way to thin.
STR and Erick's both make awesome tb's
Old Jan 26, 2003 | 08:23 AM
Default Re: TB ...whats to big? (TREVER)
Naw, it's strong as ****!
gsr_pimp88
Sep 14, 2006 05:17 PM
B20luda
Nov 13, 2004 05:03 AM
fastlude69
Dec 22, 2003 08:31 AM
I Gotta Question
23
Jan 20, 2003 06:45 AM
turbo83lude
Oct 2, 2002 05:44 AM
