what plug gap, fuel pressure, and timing to use?
Old Jan 26, 2003 | 10:49 PM
DLOTYPER's Avatar
Default what plug gap, fuel pressure, and timing to use?
got a DRAG gen 3 on a gsr, rc 310's,vortech fmu, Holley FPR, intank 255 lph, msd 6al, what fuel pressure should i have at idle? and what gap should my pugs be at, and also, can anyone suggest a safe timing set here. my FMU is using an 8:1 disk right now also. Can go up to 10 to 1. Any suggestions?? let me know thanks.
Old Jan 27, 2003 | 09:12 AM
TurboTegB18c's Avatar
Default Re: what plug gap, fuel pressure, and timing to use? (DLOTYPER)
Gap plugs to .30 if running stock ignition. As for timing, maybe retard 2degrees if you want to be super safe. If your running 310cc injectors, the 8:1 disc would be fine but i would get it dyno tuned to see what kind of a/f ratios u are running.
Old Jan 28, 2003 | 07:50 AM
DLOTYPER's Avatar
Default Re: what plug gap, fuel pressure, and timing to use? (TurboD16Z6)
if im using a msd 6al with a blaster 3 coil, then what gap should i be?? from reading the plugs i can tell im still running rich, but i would like an afc or hondata, to maximize the cars potenial, only running about 8.5 psi. need to get on the dyne, also what should my static fuel pressure be at idle?? thanks
Old Jan 28, 2003 | 08:30 AM
If u have the msd 6al, i would first try gapping to .35 and see if it misses up top. What your trying to acheive is the largest gap you can run by not miss firing up top. The larger gap should give you better throttle response. Static fuel pressure should be around 38-40 at idle.
Old Jan 28, 2003 | 11:19 AM
camp1320.com's Avatar
you can run the plugs at about .28 which comes pregapped on NGK plugs for turbo charged appl. r5671a-8 would be nice set to try .!! or the
bcpr7es-11.fuel pressure should be around 38-40 like turbod16z6 said.
therealtime
Jun 22, 2004 07:21 AM
guest
Jul 1, 2002 03:11 PM
Vtec integra
Apr 27, 2002 08:59 PM
uneekcrx
Apr 8, 2002 08:31 AM
