Please Help! Compression #'s
Old Jan 25, 2003 | 03:09 PM
Red99CivicSi's Avatar
Default Please Help! Compression #'s
I have a boosted GSR block with Si head. I originally had Endyn RW pistons in my Si block. When I switched to the GSR block I just used those pistons. So here is the deal, what kinda compression numbers should I be seeing with this setup: Stock Honda head Gasket, Stock Si head, Gsr block with Si 81.5mm Endyn Rw pistons supposedly rated at between 8.06-8.40:1, turbo kit. I did a compression check with the motor hot and cold and here are the results:
Cylinder 1: 155
Cylinder 2: 125
Cylinder 3: 150
Cylinder 4: 155
Old Jan 25, 2003 | 04:15 PM
BudaKai's Avatar
Default Re: Please Help! Compression #'s (Red99CivicSi)
So, umm, are asking if they are off?
Old Jan 25, 2003 | 04:23 PM
AlphaKennyWun's Avatar
Default Re: Please Help! Compression #'s (tzsir)
Im getting around 165-170 across on a built b18c1. Yours is not too low especially since you have lower compression than me. You could just have a leaky valve seal or valve that needs adjusting.
lv2exl8
Jun 27, 2006 09:03 PM
Dan GSR
Mar 1, 2004 01:35 PM
done
Apr 29, 2002 06:04 AM
