blow off problem
Old Jan 24, 2003 | 05:54 PM
eclipsegst4's Avatar
Default blow off problem
i just installed a greddy type-s BOV along with an upper intercooler pipe, and an intake. i installed everything to spec. my problem is... the car has no power due to a leak or something from the BOV. it sounds like it is leaking as i accelerate. i tried adjusting it tighter and softer, but nothing really works. any suggestions?
Old Jan 24, 2003 | 05:58 PM
lazerus's Avatar
Default Re: blow off problem (eclipsegst4)
where do you have the vacuum nipple hooked up to?
Old Jan 24, 2003 | 06:00 PM
Default Re: blow off problem (lazerus)
i have the vaccuum from the intake manifold going to the purple anodized nipple, and the other one i spliced into the vaccuum hose coming from the turbo outlet to the wastegate actuator.
Old Jan 25, 2003 | 11:02 PM
spooled b16's Avatar
just as a safety i would get away from the vac source from the turbo. The wastegate in my opinion with an internal one like yours should be hooked up to the charge pipe with no other tees, but since your turbo has a vac. port of it's own leave the wastegate hooked to that by itself and hook the bov into a source from the manifold. It is very unlikely the bov is to blame since there is not many things that can malfuntion in them.
Check your connections including all charge pipes and vac.
Hope this helps
Old Jan 26, 2003 | 02:36 AM
BudaKai's Avatar
Are you sure the flange isn't leaking? Could the BOV not be mounted properly. Did you use a gasket for it? I bet it isn't mounted properly.
Mario.
Jun 2, 2005 03:25 PM
kfar09
Jul 9, 2004 07:16 PM
FOrSfEd
May 20, 2004 04:57 AM
BoOsTiN Dc2
Sep 28, 2003 08:15 PM
JohnShaft
Aug 22, 2001 11:10 AM
