Ls head set up
Old Jan 24, 2003 | 11:08 AM
dwilson's Avatar
Default Ls head set up
Hey guys needing some opinions on which way to go on this. I am wanting to be able to rev the motor to 7,500 rpms and for it to flow decent. This is going on a LS turbo set. What would be a reliable way to go and also not break me at the same time?
Old Jan 24, 2003 | 11:36 AM
RyanAutry's Avatar
Default Re: Ls head set up (dwilson)
I guess a port and polish with oversized valves and muti-angle valve job.
Ti Retainers and Dual Valve Springs.
That should do it.
Old Jan 24, 2003 | 11:39 AM
dwilson's Avatar
Default Re: Ls head set up (RyanAutry)
Yeah, i was looking for something a little simplier, I know the Port n Polish is a must, but how much can i get away with just stock valve train?
Old Jan 24, 2003 | 12:25 PM
mos's Avatar
mos
7500rpm isn't that high. You should be able to rev up there without any mods. You might want to get some aftermarket valve springs to help prevent float if you're worried about it. Some mild cams to move your torque curve up the RPM scale a bit might compliment your new redline also.
Old Jan 24, 2003 | 12:41 PM
boostaholic's Avatar
Default Re: Ls head set up (mos)
I rev my LS motor to 7500rpm with a stock head. Not all the time, but if i'm racing i'll rev it that high. Peak hp starts to level off right around 7300-7500rpm on my setup.
Old Jan 24, 2003 | 01:10 PM
BudaKai's Avatar
Default Re: Ls head set up (boostaholic)
What's your set-up? If you don't mind me asking.
Old Jan 24, 2003 | 04:07 PM
93LSivic's Avatar
Default Re: Ls head set up (tzsir)
I revved my stock LS to around 7800. Now the motor is built and Ive gone to 8800 so far. 4 angle ferrea 1mm over on in/ex, p&p, crower dual race springs, stock retainers -- i dont trust the expensive ones that wear out.
jdm.fanatic
Dec 18, 2008 07:31 PM
JadeGreenEF9
Oct 19, 2006 09:45 AM
the DA in HONDA
48
Apr 1, 2005 11:53 AM
JChops
15
Oct 12, 2003 09:47 AM
LshatchTurbo
Apr 20, 2002 11:41 AM
