Please HELP! Need Advice Quick!
Old Jan 27, 2003 | 07:00 AM
forcedaccord95's Avatar
Default Please HELP! Need Advice Quick!
hey guys,
here's the deal. I had my sleeve made at Darton and it has been a nightmare.
I have a f22-b1, the stock bore is a 85mm with a 8.8:1 compression. Darton said it would be two weeks before being made, then 4 weeks, then five and friday they called and told me that they screwed up and bored the sleeve to a 85.5 mm( to big). So now after the machine shop finishes off the sleeves, they will be way to large!
I called race engineer where I originally ordered the wisco 8.8:1 pistons and they said they could return these and get me a pair of 86mm arias pistons. The problem is, they have two different compression rates and I am jugging with which one to go with. They have a 8.2:1 and a 9.5:1 compression. I didn't know if dropping the compression this low would make my car a slug off the line, so I was leaning towards going with the 9.5:1 and running 8-10 lbs of boost, please let me know what you'll think!
Another thing is the price. the wiscos were 369.00 and the arias are 498.00, a 130.00 diffence, what do you guys think is the chance of getting the money from darton for the inconvience?
thanks
shane
[Modified by forcedaccord95, 4:07 PM 1/27/2003]
Old Jan 27, 2003 | 07:23 AM
swrdply400mrelay's Avatar
Default Re: Please HELP! Need Advice Quick! (forcedaccord95)
Damn I'm sorry to hear that. I've had 8.5 compression before and it was horrible. For 8-10lbs, I'd go with the 9.5 and if you do boost higher, you could always get a slightly thicker headgasket to lower compression a bit. I'd ask Darton to pay the difference and show the receipts to prove it.
Old Jan 27, 2003 | 08:55 AM
TurboTegB18c's Avatar
Default Re: Please HELP! Need Advice Quick! (swrdply400mrelay)
I would definately stick with the 9.5:1 compression. If tuned correctly, you could boost alot more then just 8-10 psi on it.
Old Jan 27, 2003 | 09:06 AM
98civicEX's Avatar
that's complete horse sh*t, yes people make mistakes, but you should have to pay very little for that complete block IMO. you're the customer so remember that....they should want your business....
Old Jan 27, 2003 | 09:08 AM
Farnsrocket's Avatar
Default Re: Please HELP! Need Advice Quick! (98civicEX)
At least have them pay the difference for the pistons, if not also for the inconvenience!! Good luck!
Old Jan 27, 2003 | 11:34 AM
b16ahybrid's Avatar
Default Re: Please HELP! Need Advice Quick! (Farnsrocket)
Go with the 9.5:1 pistons and they should pay the difference in price, or have them resleve it with the proper bore.Either way they will end up paying for something.Everybody makes mistakes, but you you shouldn't have to pay for someone elses.
Old Jan 27, 2003 | 11:36 AM
good news guy! darton paid the 130.00 difference for the pistons! But, I think I have another problem. I have a new factory oem head gasket, its bore is 85mm and the new bore is 86mm. will this still work. I was told yes because it is 1mm, very small. What do you think. I hope so, cause if not i'm SOL. its hard enought to find parts for my car, much less a custom head gasket. please let me know
[Modified by forcedaccord95, 8:38 PM 1/27/2003]
JarrettL
Honda S2000
Jun 14, 2012 03:09 PM
regamaster
12
Mar 18, 2004 04:59 PM
genop
Sep 17, 2003 10:45 PM
sparknblaze
Aug 15, 2002 08:31 PM
