Choosing intercooler size
Old Jan 25, 2003 | 08:40 PM
StyleTEG's Avatar
Default Choosing intercooler size
I am trying to figure out what intercooler size would work best for my B18B turbo project/kit/whatever.
I am going to be running a T3 turbo with .42 compressor a/r and .48 turbine a/r, no more than 6psi *max*. My goal is to have it spool very quickly, as I would like to use it effectively with autocrossing.
So any formula or recommendation on how to find the right size intercooler for my goals, with out to much pressure loss?
Thanks in advance.
Old Jan 25, 2003 | 09:17 PM
RyanAutry's Avatar
Default Re: Choosing intercooler size (StyleTEG)
This should be the perfect size for you...
https://honda-tech.com/zerothread?id=387085
Old Jan 25, 2003 | 09:37 PM
StyleTEG's Avatar
Default Re: Choosing intercooler size (RyanAutry)
I was thinking more along the lines of something this sized
Old Jan 25, 2003 | 09:53 PM
RyanAutry's Avatar
Ok then.
Old Jan 25, 2003 | 10:07 PM
Full-Race Javier's Avatar
FWIW im running a t25bb @7psi with a t3 comp wheel on my 1.6L nissan engine. my IC is 28.5"*8.5"*3.0" with 2.25 inlets and 2.0" IC piping. as far as spool up is concerned....it makes 7psi in every gear very quickly. for example, i can get 7lbs in 1st before 4000rpm with a leaking manifold
Old Jan 25, 2003 | 10:42 PM
running10s's Avatar
Default Re: Choosing intercooler size (javierb14)
what about just like a Drag Turbo Sized intercooler I think would work great
Old Jan 26, 2003 | 05:47 AM
Phoenix GSR's Avatar
if you have a civic that eclipse intercooler will work great..
in an integra it is a little harder to find a good place for it
Old Jan 26, 2003 | 06:15 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Choosing intercooler size (Phoenix GSR)
get one like this
[Modified by Boosted97Lude, 10:15 AM 1/26/2003]
Old Jan 26, 2003 | 06:44 AM
C-Murdock's Avatar
Default Re: Choosing intercooler size (Boosted97Lude)
get one like this
God damn man, who the hell makes that front end ?
Old Jan 26, 2003 | 06:45 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Choosing intercooler size (C-Redrum)
http://www.jtautostyle.com
Old Jan 26, 2003 | 07:08 AM
StyleTEG's Avatar
Its on an integra, so I am expecting it to be a little hard to find a mounting position. I can get the piping made custom, so as long as I can find space I should be all set.
I would like to be fully spooled at 6psi by 3,000rpm. Would the size of the intercooler effect this?
The reason have been planning on getting a smaller intercooler, is I was told the larger intercooler would create more piping which in turn would lengthen the spool up time.
Old Jan 26, 2003 | 07:17 AM
integra-modder's Avatar
Its not more piping that makes the turbo spool longer.
If you have a larger IC, the area inside of your piping and IC takes longer to pressurize since the volume is bigger.
You want to keep the air volume down between the turbo and the IM to keep your spool time low.
Old Jan 26, 2003 | 07:30 AM
EMod Civic's Avatar
Default Re: Choosing intercooler size (integra-modder)
Has anyone ever done a back to back comparison of a large IC/long pipe vs. a smaller IC/short pipe to compare the throttle response/lag? I was very concerned about this when designing the IC setup for my autocross car, because any lag or throttle response issues are going to cost time. Because of my concern, I went with an under hood mounted ice water to air IC, which basicly fit in line with the charge pipes I was running with no IC. It works great, no doubt. I didn't feel any difference in throttle response or lag, and picked up some power as well. I also only got a pressure drop of less than 1/2 psi.
What I don't know is how the car would feel with a larger FMIC and more piping. Would it really make a noticable difference? The ice water system works great, but it is very high maintenance, with all the ice I have to shovel into it between runs.
-Chris
Old Jan 26, 2003 | 10:55 AM
StyleTEG's Avatar
So I would want a smaller intercooler, like the one I posted above.. instead of a larger FMIC?
Old Jan 26, 2003 | 11:02 AM
lazerus's Avatar
"FWIW im running a t25bb @7psi with a t3 comp wheel on my 1.6L nissan engine. my IC is 28.5"*8.5"*3.0" with 2.25 inlets and 2.0" IC piping. as far as spool up is concerned....it makes 7psi in every gear very quickly. for example, i can get 7lbs in 1st before 4000rpm with a leaking manifold"
T-25 Ball bearing 1.6L 7 psi before 4000 rpm? wow amazing. I have a T3/t04E 1.6L and i hit 12 psi at 3,200 rpms.
sorry, that just seemed like a lot of lag to me for a Bb T-25
I'll be switching from a small sized intercooler, to a VERY large intercooler here, soon, and i can post some results of the spool up times here. it's hard to know exactly when i get full spool, becase as soon as it hits... the tires just spin, but i can datalog it :-D
Oh, and also. That SMIC intercooler will work very well.
[Modified by lazerus, 12:03 PM 1/26/2003]
NewportSI
Apr 18, 2005 06:10 PM
Guerillah
Oct 24, 2004 08:02 AM
VtecInteg95
May 10, 2003 09:04 AM
Pinhead
Jul 25, 2002 08:32 AM
97integraLST
Mar 8, 2002 09:14 AM
