how do i get the bolt out from my exhaust housing???
Old 01-24-2003, 04:57 PM
accordfreak's Avatar
Default how do i get the bolt out from my exhaust housing???
i got all bolts out but this one and the another one that's stuck like this one. For some reason the housing doesn't rotate! i thought it's supposed to rotate??
[Modified by accordfreak, 1:58 AM 1/25/2003]
Old 01-24-2003, 05:08 PM
TurboLude97's Avatar
Default Re: how do i get the bolt out from my exhaust housing??? (accordfreak)
did you try pushing harder?? you know put your back into it. i kown i had to tighten one bolt and then rotate mine when i put it on because i coudnt tighten it when it was on.
Old 01-24-2003, 05:51 PM
lazerus's Avatar
Default Re: how do i get the bolt out from my exhaust housing??? (TurboLude97)
what happens is rust "welds" the cartridge and exhaust housing togeather, you may try heating it up to 350 degrees, and then tapping the housing to break the rust loose, the housing does turn and will turn, it just takes some work.
Brad
Old 01-24-2003, 06:58 PM
PreIudeSI's Avatar
Location: California ... Beauuutiful, so cal, pwnited States
Default Re: how do i get the bolt out from my exhaust housing??? (lazerus)
yeah try a little harder, get some anti corrosive stuff in there.
[Modified by PreIudeSI, 3:59 AM 1/25/2003]
Old 01-24-2003, 07:01 PM
JM Performance's Avatar
Default Re: how do i get the bolt out from my exhaust housing??? (PreIudeSI)
rubber mallet.....it'll help loosen things up.
BlackBeastEK
01-24-2007 06:23 PM
BodyKits NW
03-10-2006 02:38 PM
jolt-tsp
07-01-2005 06:07 PM
BlueSi2k
03-31-2004 01:56 PM
Quick Reply: how do i get the bolt out from my exhaust housing???
