best turbo
Old Jan 25, 2003 | 08:31 PM
LonelyDriver02's Avatar
Default best turbo
Hey, i've got a 00 si with an f-max kit on it. my current turbo's a turbonetics t3/t4 and i'd like to upgrade to something that spools a little faster and has less lag to it. Right now, it starts spool at 3,000 rpms. Its mainly a street driven car and I'd like something that can make 300-350 whp. A ball bearing would be nice, but kind of expensive. Any suggestions please? Thanks
Old Jan 25, 2003 | 08:43 PM
MiraiZ's Avatar
Default Re: best turbo (LonelyDriver02)
keep what you have...
Old Jan 25, 2003 | 08:46 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: best turbo (MiraiZ)
You can make that power with what you have now. If you get full boost at 3000rpm then thats pretty damn good.
art
Old Jan 25, 2003 | 08:50 PM
rOby's Avatar
Default Re: best turbo (Arturbo)
or u can upgrade to precision.....dont drop the ball Art!!! bacardi 151 is pecsial
Old Jan 25, 2003 | 08:55 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: best turbo (rOby)
Yes, I could make a sale but Im trying to save him some money. Use what you have and your wallet will love you for it.
Old Jan 25, 2003 | 09:20 PM
Domestic_Violence's Avatar
that Hybrid turbo will work real nice, quick sppol up and lot's of volume!
Old Jan 25, 2003 | 10:58 PM
MiraiZ's Avatar
if you wanna spool earlier...get a boost controller and wrap your mani...they both help a tad...may be able to get it down to 2500...any lower, you will need to boost up the compression a bit, but 2500-3000 is plenty good!
Old Jan 26, 2003 | 06:09 AM
ekb18c's Avatar
art
I wished my turbo would get FULL BOOST at 3000 rpm.
Old Jan 26, 2003 | 06:45 AM
GS-Rcivic's Avatar
so what do you think would a greddy 15G turbo spool at with 10.6:1 copression pistons??
Old Jan 26, 2003 | 09:23 AM
Pelican's Avatar
Default Re: best turbo (GS-Rcivic)
I gotta reply cause I got schooled on this one before.
A high compression setup will not spool a turbo any faster than a lower compression setup. It deals more with displacement.
Think about it. a 1.8L with 9:1 CR spits out 1.8L of spent gas every 2 Revs.
And a 1.8L with 11:1 spits out 1.8L of gas every 2 revs, but has more power.
So both spool at some random number........3500, but the 11:1 gets to 3500RPM quicker than the 9:1 because the power output is higher.
Old Jan 26, 2003 | 09:43 AM
ekb18c's Avatar
Default Re: best turbo (Pelican)
I beg to differ!
Old Jan 26, 2003 | 09:47 AM
Phoenix GSR's Avatar
higher compression spools faster because there is more exauhst energy...
basically like 1.8l of air coming out harder/faster than low compression
or that is what I thought..
Old Jan 26, 2003 | 09:49 AM
Pelican's Avatar
Default Re: best turbo (ekb18c)
maybe the gas temperatures would be higher, but shouldn't it spool at the same RPM, just the higher Compression Motor get to that RPM faster............
**The only thing I'm saying is that Full boost RPM should be the same. That's it**
[Modified by Pelican, 1:57 PM 1/26/2003]
Old Jan 26, 2003 | 09:53 AM
Pelican's Avatar
Default Re: best turbo (Phoenix GSR)
same "literage" and same piston speed..... But the RPMs <u>DO</u> climb faster, because there is power power per stroke
Old Jan 26, 2003 | 10:08 AM
GS-Rcivic's Avatar
OK we got that answered, now do anyone know if the greddy SOHC kit work on an b18c1? and are there any mods that needs to be done?
Old Jan 26, 2003 | 01:35 PM
Joseph Davis's Avatar
No, you don't. Low spooling means no traction off the line. I spool at 2500 rpms, and off 4 psi non-IC w/ Azenis I can sit and spin most the way through third gear before hooking... and that's without trying hard, just ******* up a launch and not taking my foot far enough out of the gas pedal in first and on shift into second and then deciding the hell with it - make a big cloud of tire smoke and pretend I'm bad or something. /me rolls eyes.
I also bark 4th gear, and not (entirely) due to power output. A little too much negative camber and a chassis prone to wheelhop are killing off my traction.
Your mileage may differ with a low spooling turbo depending on how your suspension and power level are, but my $0.02 is aim for a spool of 3500+ rpm, even for street car, unless you're dealing with some gutless D-series w/ Greddy kit.
[Modified by J. Davis, 2:36 PM 1/26/2003]
Old Jan 27, 2003 | 06:57 PM
Default Re: best turbo (J. Davis)
I dont have too terrible of traction problems, of course i dont have nearly as much power as most of the rest of you do. But i guess i'll stick with my current turbo, save some cash. Thanks for all the help guys.
by the way, i like your icon with agent smith. i like the part when he was like "find them and destroy them" that was so funny.
Old Jan 27, 2003 | 07:23 PM
Rod Short's Avatar
I have to agree with Art. Save your $$ and stick with what you've got. Ball bearing turbos aren't that expensive. A GT-28 retails from us at $950. I expect to see the prices on these things start to drop.
Rod Short
Sales Manager
Precsion Turbo
JWjDM
Jan 9, 2007 03:32 PM
2fastcivic
Jun 18, 2004 05:48 PM
gsrt
Dec 23, 2002 07:54 AM
jdmciviceg
Mar 26, 2002 02:07 PM
