whats a better jrsc setup...
Old Jul 29, 2003 | 10:13 PM
justmotor13's Avatar
Default whats a better jrsc setup...
ok one of my friends has a jrsc with a 6lb pulley on his 97 gsr. I was wondering if it would be better to just stay with all gsr parts and go with a pulley upgrade and leave teh compression the way it is, or raise it to say 11:1 and run the smaller 6lb pulley. which would make more power?
Old Jul 29, 2003 | 10:17 PM
aLLjDMRalf's Avatar
Default Re: whats a better jrsc setup... (crx31286)
it wpuld make more power to just raise the boost but the raising comp. works pritty well people r just skeptycal of it, from personal ex. raise comp. boost is a good combo jus depends what his over all goals r
Old Aug 6, 2003 | 07:20 PM
MachAF's Avatar
Default Re: whats a better jrsc setup... (SlOwCrXbUtUbNbEaT)
No. Don't raise the compression and run boost.
You'll likely detonate if you aren't using race gas.
Lower the compression and boost it more. Much safer. Hence the reason why most factory turbo cars are in the 8:1 - 9:1 area.
sleeprcivic12
Dec 24, 2004 02:21 PM
MooreBoost
Jul 6, 2003 05:48 PM
ID_ten_T
Jun 15, 2003 11:11 PM
1badITR
Jul 4, 2002 10:23 PM
el_Presidente
Mar 24, 2002 02:12 PM
