hondata
Old Jul 31, 2003 | 09:21 AM
MI4eg's Avatar
Default hondata
im waiting for my hondata to get here.
quick question, if i install the 550cc injectors when i get the hondata and install the hondata i will be able to drive the car correct?? money is tight and im looking at the end of the month for dyno time. just want to make sure i could drive back and forth to work.
Old Jul 31, 2003 | 09:29 AM
ski_rebel_3's Avatar
Default Re: hondata (MI4BUILT)
I assume the shop that is sending you the hondata put a base map on it for you correct? If so you can drive on that...is it recommended..NO!..but you can. A base map is designed to get you to a dyno so be careful if you plan to drive around on it for a while.
Old Jul 31, 2003 | 09:58 AM
TurboTegB18c's Avatar
Default Re: hondata (ski_rebel_3)
As long as you get a good base map, you should be fine driving on it for a while. Paul
Old Aug 4, 2003 | 05:45 PM
LJR-LUDE01's Avatar
drive the rsx man, knowing you I bet you **** something up in that time
Old Aug 4, 2003 | 05:49 PM
LiLOtaku's Avatar
The base hondata maps are VERY conservative and you'll be running pretty rich with them. But yes they are safe to drive on, but don't do it for too long or you'll be wasting a good amount of gas.
bcp0715
Acura TSX
Apr 13, 2013 05:14 AM
ITR9788
Jun 9, 2004 02:14 PM
dabrown
Jul 30, 2003 06:08 AM
g2turbo
Nov 23, 2002 06:00 AM
jamal-188
May 5, 2002 08:11 PM
