will a 3" dp fit in here
Old Aug 1, 2003 | 10:54 AM
DubyaAye's Avatar
Default will a 3" dp fit in here
if it will, what degree of bends do i need? its a garrett t3/to4e on right now but my sc61 is going to go in later, so i not sure will it have enough room or not.
Old Aug 1, 2003 | 10:57 AM
done's Avatar
Default Re: will a 3" dp fit in here (DubyaAye)
maybe
Old Aug 1, 2003 | 10:59 AM
clendaniel's Avatar
You'll need a slim fan but it should...I made a 3" for a similar setup not too long ago. The first bend will have to be cheated slightly like the smaller d/p in the pic but once you get the fan outta the way it should be alright.
--Ian
Old Aug 3, 2003 | 09:27 PM
DubyaAye's Avatar
Default Re: will a 3" dp fit in here (clendaniel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clendaniel &raquo;</TD></TR><TR><TD CLASS="quote">You'll need a slim fan but it should...I made a 3" for a similar setup not too long ago. The first bend will have to be cheated slightly like the smaller d/p in the pic but once you get the fan outta the way it should be alright.
--Ian
</TD></TR></TABLE>where can i get a slim fan at?
Old Aug 3, 2003 | 09:42 PM
psileepR's Avatar
New User
why not just doing a pusher fan??? they are only like 60-70 bucks for a 12" at kragen, pepboys etc
Old Aug 4, 2003 | 12:19 AM
swlabhot's Avatar
Looks to me like your radiator will be in the way too...even if you get a slimline fan
Old Aug 4, 2003 | 12:51 AM
legendboy's Avatar
Default Re: will a 3" dp fit in here (swlabhot)
if you run a slim fan and wrap your dp with heat rap you should be ok
Old Aug 4, 2003 | 01:06 AM
Full-Race Javier's Avatar
u could always use a swedge and transition from 2.5 to 3.0in if u dont have any room.
Old Aug 4, 2003 | 01:11 AM
Blueprint's Avatar
Default Re: will a 3" dp fit in here (javierb14)
It will fit for sure if you run a pusher fan.That thick fluidyne isnt helping on clearance issues either. The bad thing is it will create alot of heat depending on how rich or lean your motor is running. It would be wise to wrap the DP with thermal wrap. You would be better off turning the turbo the other way and as long as you dont have AC you will be clear and free from anything in the way and the 3 inch DP would be perfect.
platinum00
Jul 30, 2006 07:55 AM
pro547
May 10, 2006 07:06 PM
silverb18
Sep 11, 2004 06:47 PM
6MTV6
Jun 8, 2004 11:04 AM
DLB1994
Jan 23, 2002 02:56 PM
