Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male
I just got this fitting, and tthe only difference I can see is that one side is larger than the other side, but I wanted to know which side of the fitting to screw into the block?
Thanks
Thanks
Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (AcCO12D95)
I would imagine whichever side fits in the block would be the one you use ...my experience showed the smaller one is the side to use. HTH
-Ryan
-Ryan
Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (Kwuaymaikrup)
yea, i just matched up the threads with a npt fitting. it is the smaller end that goes into the block...hopefully!
I believe bspt has a tapered end, that is the difference between bsp and bspt
Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (bluebullet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet »</TD></TR><TR><TD CLASS="quote">I believe bspt has a tapered end, that is the difference between bsp and bspt </TD></TR></TABLE>
thats correct. bsp(t) t is for tapered
HT's Biggest Loser
Re: Which side of this fitting is BSPT? It's a 1/8" bspt male to 1/8" npt male (sparkz)
Nobody said anything about BSP tho, the question at hand was bspt and npt. The block should be bspt, and the npt should go to the lines.
hasback*
02-15-2007 01:30 PM
