What coolant W/ copper headgasket?
I was told that you can not use regular coolant with a copper head gasket because it will corrode it and that I need to run straight water. Is this true? It makes sense but is there some sort of additve to mix with regular coolant? Thanks for your help.
I am a bad person
Re: (BoostedB20A)
i dont use the copper gaskets but my buddies vr6 jetta has one and he uses reg coolant always. best thing to do is call up cometic or sce and ask.
Re: (BoostedB20A)
A long time ago I asked if my homemade elbow would be ok for coolant, seeing as how its made out of copper. Here is a pic.
Anyways i was told its ok to use copper in my cooling system, and no corrosion will occur. Here is the link if you are interested
https://honda-tech.com/zerothread?id=495726
Apparantly, copper ha sbeen used in old radiators so its all good
spcrxracer
02-27-2005 11:16 AM
