What injectors to run with JRSC?
I have a Lude that is SC'd and I want some injectors. What are the right injectors for me? and Where can i get them for relatively cheap prices? (I'm try'n to get hondata soon as well)
Re: What injectors to run with JRSC? (B16AHondaSi)
90% of the supercharged lude people who run hondata use 550cc injectors your stock injectors are 290cc. If I had a lude it would get 550cc
Re: What injectors to run with JRSC? (LostLude)
The Jackson Racing Rising Rate Fuel Pressure regulator is a 5 to 1 ratio. I ran 60 psi static on my JRSC which is 95 psi at 7 pounds of boost (60 + (5 x 7) = 95). With minimal tuning on a VAFC I was able to get 12.1 air/fuel at the dyno. There is really no need to upgrade the injectors on a JRSC'd Prelude unless you are upgrading the pulley and making more boost. Sure, 95 PSI is a little hard on the injectors and the return line to the RRFPR, but it's nothing compared to the 12 to 1 Vortech I have on my turbo now at 9 PSI with a 45 psi static pressure 45 + (12 x 9) = 153 PSI!!! Still no leaks on factory injectors, but that is a little too much for me, so I am gonna upgrade the injectors with the turbo.
440s if you plan on staying at 6 psi. 550s if you would consider running 9 psi. Personally, I say just go with 550s since the latest hondata basemap was created on a JRSC lude with 550s.
Modified by sharkcohen at 6:18 AM 9/8/2003
MOGSR
01-26-2002 08:00 PM
