lets talk diy dual stage boost controllers
Old Jul 30, 2003 | 08:35 AM
buckfittyone's Avatar
Default lets talk diy dual stage boost controllers
since i was having trouble finding 12v 3 way solenoid valves,ive been trying to make a 2 stage boost controller with a 12v open /close 2 way valve and this is what ive come up with.
vaccum hose from intake manifold to 3 way tee
one end of tee to solenoid valve other
end of solenoied vented to atmosphere
other end of tee to manual boost controller
boost controller to wastegate actuator
i can see how this setup could work in theory,with solenoid closed, vaccum signal goues directly from intake ,to boost controller,to wastegate,giving you whatever boost you set the boost controller to.with the solenoid open the vaccum signal <U>should</U> completely bypass the boost controller and give you whatever max boost the actuator arm is set to give with the wastegate unplugged.
my question is ,is teeing the vaccume line a good idea?will the solenoid vent the line completely or will the actuator still be getting some kind of signal from the boost controller?
share your thoughts and ideas,i know you guys love diy stuff
Old Jul 30, 2003 | 09:12 AM
bump
Old Jul 30, 2003 | 10:15 AM
RenoRacing's Avatar
Default Re: (buckfittyone)
my friend has a dual stage boost controller that cost about 10$ to make. heres how it goes. we used one of those little boxes that is next to map sensors on 88-91 hondas, it's got two wires coming off of it and3 vaccum lines. we have the wastegate line connected to that box. when the box has no charge it goes to one of the vaccum nipples that has a little home depot valve that is open about halfway, thus boosting 6psi, then when the box recieves power via a button on the shift **** it switches to the last remaining vaccum nipple on the black box where there is another **** that can be adjusted from anywhere around 8-17 psi. so he launches and pulls first at 6psi then hit's the button and runs 14psi. it works great and cost about $10 at homedepot for the two valves and i have several of the boxes laying around.
Old Jul 30, 2003 | 01:20 PM
rioninja's Avatar
Default Re: lets talk diy dual stage boost controllers (buckfittyone)
THis is what im going to build when i get a free minute.
Its an easy concept.
Old Jul 30, 2003 | 01:34 PM
EMod Civic's Avatar
Default Re: lets talk diy dual stage boost controllers (rioninja)
That picture above is exactly like I made mine. I used one of the idle control solenoids that was part of my A/C system (86 Civic). It's located on the firewall near the MAP sensor on these Civics/CRXs and 1st gen teg's. When no voltage present, air flows through the low resistance path through the solenoid and my boost is what my wastegate is set at (5psi). When I hit the microswitch at full throttle+, the solenoid closes, and the air is routed through my Grainger ball/spring MBC, and I get 10psi. The lines have to be really short and right at the turbo/wastegate to have it react in real time. I use mine for control in corners while autocrossing (low boost at part throttle = better control when cornering)
-Chris
Old Jul 30, 2003 | 02:57 PM
RenoRacing's Avatar
Default Re: lets talk diy dual stage boost controllers (EMod Civic)
that is the same solenoid i'm talking about the idle one.
Old Jul 30, 2003 | 06:39 PM
Default Re: lets talk diy dual stage boost controllers (HavokRacing)
just what i needed to know,had to make sure the tees would be good enough
Old Jul 30, 2003 | 06:42 PM
GSRswapandslow
Guest
Posts: n/a
i guess I'll just stick with the EVAP Purge soleniod valve for mine 2 step
Old Jul 30, 2003 | 08:13 PM
egg's Avatar
egg
Default Re: (GSRswapandbanned)
would you have to make a vent also?
Old Jul 30, 2003 | 08:24 PM
Sinner's Avatar
would that work with an odb1 Idle air control valve? thats a great idea. I just made a inline MBC today and was thinking it would be great if i could rig up something like this
Old Jul 30, 2003 | 09:51 PM
turbo sol's Avatar
Default Re: (Sinner)
does anyone have a pic of this EF dual stage controller setup, i think i have the parts for it, but i am a little confused on it all.and everyone know pictures are wirth a thousand words.
Old Jul 30, 2003 | 11:33 PM
5thgencivic's Avatar
Default Re: (turbo sol)
Anybody willing to sell a solenoid or idle air control valve? Thanks.
Old Jul 30, 2003 | 11:41 PM
lazerus's Avatar
Default Re: (5thgencivic)
the junkyard will be willing, for sure :-)
Old Jul 30, 2003 | 11:45 PM
nigel's Avatar
jack one at the junk yard. man thats a great idea. I like the avcr and I want to buy it really bad. but I am also all about diy. I made my own t3 flange hehehe. took like a whole day.if anyone coulf just show a pic of where this solenoid moght be it would be great because I am fixin to go get one. couldn't you use this to bypass a normal boost controller if it decided to overboost or somthing dumb
Old Jul 31, 2003 | 12:11 AM
Default Re: (lazerus)
The junkyard here doesn't have much...
Old Jul 31, 2003 | 01:53 AM
89dxhunchback's Avatar
bump/subscribing
"yea, you you have any civics ?".... "Yes" do you mind if I check them out, I'm looking for some very specific parts?".. "Sure, $1 entry fee." "Nope, not the right model, but how much for the front end off that 93', my friend needs one ?"... "$75 bucks?" "Ok, thanx" = one free sensor of your choice, two if your pants came OEM with 2 pockets..
Old Jul 31, 2003 | 03:37 AM
T-RO's Avatar
Yes, someone please post real pictures of what everything looks like. Thanks.
Old Jul 31, 2003 | 05:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">Anybody willing to sell a solenoid or idle air control valve? Thanks.</TD></TR></TABLE> i just got one off ebay for 4 bucks brand new,mine is for a pontiac but it does the same thing
ericstambaugh07
Jun 23, 2007 09:04 AM
nicktagz
Aug 23, 2006 08:12 AM
Mugencrxsir1
Feb 22, 2006 10:02 AM
Mucackus
Apr 26, 2002 08:45 AM
_Shadow_
Nov 23, 2001 11:16 AM
