Help - ARP Rod bolt torque spec
Old Jul 29, 2003 | 03:37 PM
Scott - 93HB Si's Avatar
Default Help - ARP Rod bolt torque spec
I'm assembling the bottom end right now of an LSV, and had ARP rod bolts put into the LS rods at the machine shop...I don't have the package they came in, so I'm not sure what the torque spec is...
I know factory LS is 23 ft-lbs, and GSR is 33, but what should I do the ARP bolts up to? Can anyone help?
Old Jul 29, 2003 | 04:12 PM
RyanEJ8's Avatar
Default Re: Help - ARP Rod bolt torque spec (Scott - 93HB Si)
Which ARP bolt is it?
Old Jul 29, 2003 | 04:42 PM
Flamenco-T's Avatar
Default Re: Help - ARP Rod bolt torque spec (RyanCivic2000)
if it's the super 2000 bolts, that came with your eagle rods, it's 28 ft/lb
stan
Old Jul 29, 2003 | 06:57 PM
Default Re: Help - ARP Rod bolt torque spec (Flamenco-T)
it is the ARP 2000 bolts, 9mm, but they are on the stock LS rods. So 28 ft lbs?
Old Jul 29, 2003 | 07:30 PM
11psiTurboSI's Avatar
almost positive there are 28 ft lbs too
Old Jul 30, 2003 | 05:08 AM
Flamenco-T's Avatar
Default Re: Help - ARP Rod bolt torque spec (9psiTurboSI)
it's 28ft/lb
stan
Old Jul 30, 2003 | 05:19 AM
Cool, thanks guys!
blackeg
Mar 26, 2008 04:55 PM
Blanket Jackson
10
Aug 16, 2004 07:25 AM
b20ek
Jun 15, 2003 07:02 PM
senpai
Jun 5, 2003 09:34 AM
ladysman
Mar 21, 2003 12:08 PM
