intercooler piping question
Old Jul 29, 2003 | 01:12 PM
arjusmc's Avatar
Default intercooler piping question
i've looked at a few sites for ic piping for my 95 ls. i've tried the diy jc whitney way and they keep on blowing off. just wondering how much drag piping ran for. if anyone has some used piping or if someone has just the part from the turbo to the ic let me know. thanks again guys.
Old Jul 29, 2003 | 01:42 PM
stierhund's Avatar
Default Re: intercooler piping question (arjusmc)
did you fasten the jc-whitney pipe together well enough, or brace it to the frame of the car... that should work best unless u can find some place else that sells mandrel bent aluminum for cheaper
or get it welded in every place but the IC in/outlets
Old Jul 29, 2003 | 01:47 PM
BodyKits NW's Avatar
Default Re: intercooler piping question (stierhund)
What kinda hoses are you using? Get some good silicone hoses and run 3.5 inch wide pieces where it keeps blowing off. I buy my hoses from road race.
Old Jul 29, 2003 | 09:00 PM
arjusmc's Avatar
Default Re: intercooler piping question (BodyKits NW)
i bought some hose off of ebay. works well in most places. it just keeps on blowwing off at the turbo outlet.
Old Jul 29, 2003 | 09:15 PM
Are you using a reducer? Your probably just using a straight piece which is probably larger than turbo outlet by too much. The clamp is probably not able to hold it tight enough. I would suggest getting a reducer to get a tigher fit on both ends. That is just my 2 cents.
Old Jul 29, 2003 | 09:18 PM
1dumbscreenname's Avatar
my piping isnt the best but it does work, try going to a marine shop and asking for marine exhaust piping. it is made of rubber and reinforced with metal. the aluminized piping (exhaust) has worked well but it is heavy.
Old Jul 29, 2003 | 09:34 PM
Bspec18's Avatar
Maybe it would help if you put "beads" where the IC pipe meets the hose's and use T-Bolt clamps
Old Jul 29, 2003 | 09:41 PM
InTeGrA B18b1's Avatar
Default Re: intercooler piping question (Bspec18)
i use jc whitney pipes with silicone hoses and some from home depot running 8 psi. it stays on it. What are you using to keep the pipes together?
Old Jul 29, 2003 | 10:00 PM
ATS*Mark's Avatar
OG triple OG
Default Re: intercooler piping question (InTeGrA B18b1)
i keep hearing about the jc whitny piping , what is it , cheaper way to go than just to get a greddy intercooler kit???????? this is for a 99ex with greddy turbo
Old Jul 30, 2003 | 09:13 AM
arjusmc's Avatar
i've got a home depot reducer, but thats not where its coming off. its comming off on the next one.
Old Jul 30, 2003 | 09:17 AM
arjusmc's Avatar
i'm using jc whitney pipes with silcone couplings and home depot couplings. the couplings are held on by clamps. i think i'm going to change my set up when i get a bigger intercooler and get the setup from quikB18B. 215 isn't bad at all.
Old Jul 30, 2003 | 09:39 AM
mamaboy's Avatar
ditto on the beading....really simple to do.....or get the ends bead rolled....
Old Jul 30, 2003 | 10:07 AM
mike1114's Avatar
Default Re: intercooler piping question (mamaboy)
bead the ends of each pipe with a welder or jb weld and use t-bolt clamps, this is about the best way to do it.
I used this setup:
JC whitney piping (for those that are newby, buy some U bends from JC whitney, 1 24 inch long U bend, 2 12 inch long U bends, 1 90 degree bend all for $70 and have a buddy/welding shop/muffler shop cut and weld piping together and bead the ends of the pipes that are to be connected by silicone couplings)
Buy silicone couplings from Roadraceengineering.com 2 feet was $50, cut where needed.
Buy clamps, now some use t-bolts that are like $3.50 a piece, I found for about 50 cents more, napa sells these tourqe clamps that have springs on them to give constant tourqe like where our header meets cat. Part number 7051508 but you have to buy in boxes of 5 (5 * 3.99 = $20.00)
Old Jul 30, 2003 | 10:28 AM
EKweezy's Avatar
what kind of clamps your using, before i use the regualr clamps it didn't hold that good, now i am using the turbo clamps from Turbonetics, it holds really good
Old Jul 31, 2003 | 06:56 AM
Default Re: intercooler piping question (EAZY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EAZY &raquo;</TD></TR><TR><TD CLASS="quote">what kind of clamps your using, before i use the regualr clamps it didn't hold that good, now i am using the turbo clamps from Turbonetics, it holds really good</TD></TR></TABLE>
hose clamps are hose clamps.
Old Jul 31, 2003 | 07:25 AM
quikB18B's Avatar
Default Re: intercooler piping question (1dumbassscreenname)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1dumbassscreenname &raquo;</TD></TR><TR><TD CLASS="quote">
hose clamps are hose clamps.</TD></TR></TABLE>
incorrect, the t bolt clamps are way better than the traditional clamps(.99 ones) that come with the kits. They have a spring that keeps it securely locked, similare to design of bolt on your header/cat. Iv'e also heard nappa carries some good clamps for around 3-4 bux. Gsrsol got me the ones off vecco.net they were 3.79 a piece .
Old Jul 31, 2003 | 07:34 AM
BROOD's Avatar
Bead roll the charge pipe ends and use T-bolt clamps. The will take care of air leaks and blow-offs. Using good quality couplers helps also.
**below: I also agree that that using good couplers and bead rolled pipes will hold well even when using traditional worm style hose clamps. But I look at it this way, why not spend little extra for the T Bolt clamps. I really like the constant tension T bolts with the tension spring. There are also T bolt lcamps without the tension spring.
Modified by SLPR at 10:44 AM 7/31/2003
Old Jul 31, 2003 | 08:46 AM
CRXRageD's Avatar
Default Re: intercooler piping question (SLPR)
Sweet, I've been wondering about this for some time now. Looks like I will follow these guidelines for my new setup.
Old Jul 31, 2003 | 08:52 AM
quikB18B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arjusmc &raquo;</TD></TR><TR><TD CLASS="quote">i've got a home depot reducer, but thats not where its coming off. its comming off on the next one. </TD></TR></TABLE>
Those home depot couplers were designed to hold pvc pipe together not Intercooler pipes. Doa search on "home depot" and i'm sure you'll find some pics of these couplers literally blown to shreds. They are rubber and dont hold well to heat. For the guys who want a cheaper alternative to silcone the next best thing are those nappa radiator hoses.
Old Jul 31, 2003 | 09:20 AM
Default Re: intercooler piping question (quikB18B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
Those home depot couplers were designed to hold pvc pipe together not Intercooler pipes. Doa search on "home depot" and i'm sure you'll find some pics of these couplers literally blown to shreds. They are rubber and dont hold well to heat. For the guys who want a cheaper alternative to silcone the next best thing are those nappa radiator hoses. </TD></TR></TABLE>
all of my piping has been held together with marine exhaust piping. its a high grade rubber that is reinforced with a steel layer in the moddle. these badboys will be in perfect condition the day my car rusts itself to nothing.
Old Jul 31, 2003 | 09:22 AM
incorrect, the t bolt clamps are way better than the traditional clamps(.99 ones) that come with the kits. They have a spring that keeps it securely locked, similare to design of bolt on your header/cat. Iv'e also heard nappa carries some good clamps for around 3-4 bux. Gsrsol got me the ones off vecco.net they were 3.79 a piece .</TD></TR></TABLE>
what do these clamps look like. i have used these regular clamps on 24psi turbo cars forever and have never had any problems.
Old Jul 31, 2003 | 09:27 AM
quikB18B's Avatar
Im sure with the right combination of piping, silcone, the normal clamps can hold boost, but i was just correcting you that there are better clamps. Go to http://www.vecco.net they have pictures thier .
Old Jul 31, 2003 | 11:04 AM
redlinegsr's Avatar
I have to agree with Iggy (quikb18b) you even had a little trouble with your old rev hard setup and those everyday clamps that come with the kit. I like the idea and cost savings of the JC Whitney but also the piping he has for sale is a
kreatekustomz
Dec 19, 2009 07:45 PM
bart2546
Mar 5, 2007 06:20 PM
Integra GSR 95
Apr 29, 2005 10:01 PM
guywitaDA
Feb 13, 2005 10:15 AM
OKSolSi
May 7, 2002 12:08 AM
