EMS help...
Old Aug 1, 2003 | 04:29 AM
SSS2000's Avatar
Default EMS help...
I installed v.94 on my laptop, plugged it into the EMS and clicked "connect". The status box comes up and says:
ecu offline
online
offline
online
etc.
red text at the bottom of the page keeps flashing ECU OFFLINE
The ignition is in the on position, the fans are on, the car will crank but whats wrong with my EMS?
Thanks for any help!
Old Aug 1, 2003 | 04:34 AM
Tinker219's Avatar
Default Re: EMS help... (MilanoRedLST)
try cycling the power on and off...ie, turn the key on and off. Otherwise, make sure you have power to the ECU, ie, the 15amp fuse...
Old Aug 1, 2003 | 04:54 AM
clendaniel's Avatar
Try putting v.89 back on it and then update it again. I had a similar issue on a friends and was able to play around with it and get it fixed. On a side note...you should really consider downloading v1.03...much improved over the old revisions.
--Ian
Old Aug 1, 2003 | 06:43 AM
SSS2000's Avatar
Default Re: EMS help... (clendaniel)
I will try both versions as soon as I get home from work...ttt
Is there something to convert v.94 calibration files to v1.03 yet?
Old Aug 1, 2003 | 08:11 AM
Bottoz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRedLST &raquo;</TD></TR><TR><TD CLASS="quote">I will try both versions as soon as I get home from work...ttt
Is there something to convert v.94 calibration files to v1.03 yet? </TD></TR></TABLE>
Yes, there are many new 'wizzards' included.
http://forum.aempower.com/bbs/viewtopic.php?t=4385
Bottoz
Old Aug 1, 2003 | 10:07 AM
SSS2000's Avatar
Default Re: EMS help... (Bottoz)
Could this possibly be the Laptop?
Modified by MilanoRedLST at 2:50 PM 8/1/2003
Old Aug 1, 2003 | 11:32 AM
Mase's Avatar
try running the recovery software, ive seen a couple instances where its picky with the laptop connection.
lemme see if i can find the link
http://forum.aempower.com/bbs/viewtopic.php?t=1500
check that link.
Old Aug 1, 2003 | 11:35 AM
Mikeyslude's Avatar
Version 1.03 is available now and I heard it has a few bug fixes. check it out at http://WWW.AEMPOWER.COM
Tinker219
Oct 2, 2004 09:24 PM
i20ar
Jul 19, 2004 07:42 AM
Universal Magnetic
Aug 10, 2003 01:17 PM
Malgerus
48
Mar 16, 2003 10:07 PM
