need help with zex kit
Old Jul 30, 2003 | 02:30 AM
TURBO B's Avatar
Default need help with zex kit
ok my friend has an 89 hatch with a 91 ls motor in it i helped him do everything it has intake and running open header ok the motor runs fine but when he sprays it seems to be strong 1st 2nd and 3rd but in 4th it like putters out and loss of power and reason y that would be happening all help will be appreciated
Old Jul 30, 2003 | 09:25 AM
TURBO B's Avatar
bump
Old Jul 30, 2003 | 11:33 AM
TURBO B's Avatar
Old Jul 30, 2003 | 11:36 AM
DaveF's Avatar
Default Re: need help with zex kit (TURBO B)
is it running lean on top end?
Old Jul 30, 2003 | 11:39 AM
stinker504's Avatar
Running low on bottle pressure???? Maybe
Old Jul 30, 2003 | 02:13 PM
TURBO B's Avatar
not running low on bottle pressure
TURBO B's Avatar
i dont know if its running lean no a/f gague
Old Jul 30, 2003 | 04:23 PM
TURBO B's Avatar
any thing else u can think of
Old Jul 31, 2003 | 12:06 AM
TURBO B's Avatar
up up up
Old Jul 31, 2003 | 02:01 AM
TURBO B's Avatar
one more time before bed
Old Jul 31, 2003 | 02:53 AM
DaveF's Avatar
Default Re: (TURBO B)
how big of a shot?
whats the timing set at?
what octane gas is he runnning?
what spark plugs is he running? what are they gapped at?
Old Jul 31, 2003 | 10:46 AM
TURBO B's Avatar
65 shot timing is set back 2degrees and 93 octane gas and im not sure about the spark plug hes running or what there gapped at what should they be gapped at
Old Jul 31, 2003 | 10:58 AM
redlinegsr's Avatar
Well one thing is for sure is it isnt running rich or lean....the zex kits signatiure is that it adjust fuel according to how much bottle pressure you have. Does this problem only occur when on the bottle or does it do it on motor also?
Old Jul 31, 2003 | 12:49 PM
TURBO B's Avatar
the bottle pressure is at a little above 60 i think is that how it works or is it 600 something like that and no it doesnt do it all motor only on the bottle
Old Jul 31, 2003 | 04:16 PM
TURBO B's Avatar
up up up
Old Aug 1, 2003 | 12:14 AM
TURBO B's Avatar
bump bump bump
Old Aug 1, 2003 | 03:07 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO B &raquo;</TD></TR><TR><TD CLASS="quote">the bottle pressure is at a little above 60 i think is that how it works or is it 600 something like that and no it doesnt do it all motor only on the bottle</TD></TR></TABLE>
bottle pressure abouve 60? i would hope so. when i had a zex kit my bottle pressure's were 850-1300. sometimes more sometimes less. depending on how full or empty it was at the time.
good luck with the zex.
Old Aug 1, 2003 | 08:07 AM
TURBO B's Avatar
ok well the bottle pressure is at 800 steady with a full bottle
Old Aug 1, 2003 | 08:18 AM
HotRodDelSol's Avatar
The low botle pressure could be part of it. You can heat the bottle up with a heating pad on high if you're too poor for a bottle heater. Either that or leave the car parked in the sun for a while. Safe operating pressure is around 900-1200 psi.
Also, if you're getting all the way to 4th gear, you're probably going well over the recommended 15 seconds of spraying. Just something to remember if something blows in the motor
It wouldn't be a bad idea to compression test it, check the plugs, get a fuel pressure guage and regulator, and then go to a dyno with a wideband and make sure you aren't going way lean. An A/F guage is not much more than a light show for your guage pod
Old Aug 1, 2003 | 10:43 AM
TURBO B's Avatar
yeah we did a compression test it was fine a little to high for a stock ls 210 and yea i told him to get an a/f gauge
adamrich33
Feb 8, 2007 02:06 PM
Azn Kenny
Mar 7, 2006 06:56 PM
cliff666
Nov 14, 2003 10:18 PM
Goinfasterthanu
Nov 4, 2003 06:34 AM
lsteggy
Dec 17, 2002 04:01 AM
