for the big boost heads
Old Jul 30, 2003 | 01:56 PM
BoostedsiR's Avatar
Default for the big boost heads
I talked to jeff today from fulll race and with his kit running like 23 - 25 lbs of boost on a ls sleeved rods and pistons all thoose goodies, what type of injectors should I run? Jeff told me msd but I cant find them what are you guys using let me now the size and all of that
Old Jul 30, 2003 | 02:05 PM
TurboTegB18c's Avatar
Default Re: for the big boost heads (BoostedsiR)
Injectors size is rellevant to how much power ur looking to make, so what are your goals? Paul
Old Jul 30, 2003 | 02:11 PM
BoostedsiR's Avatar
Default Re: for the big boost heads (TurboTegB18c)
between 400 - 500 whp
Old Jul 30, 2003 | 02:18 PM
DubyaAye's Avatar
i want to know too. i got everything ready but injectors.
Old Jul 31, 2003 | 02:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR &raquo;</TD></TR><TR><TD CLASS="quote">between 400 - 500 whp</TD></TR></TABLE>
I would recommend around 780cc injectors or so, i'm running the 780cc right now and at 40psi fuel pressure, at 450whp, hitting 85% duty cycle. So right around where i'm at except u can turn up the fuel pressure a little if your hitting higher duty cycles. Paul
Old Jul 31, 2003 | 02:42 PM
piara's Avatar
RCs are good
Old Jul 31, 2003 | 08:25 PM
tony1's Avatar
Default Re: for the big boost heads (piara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piara &raquo;</TD></TR><TR><TD CLASS="quote">RCs are good </TD></TR></TABLE>
I've used a ton of injectors in the past and never had any problems with any of them EXCEPT for RC. I've had 7 sets of rc's go bad...
Old Jul 31, 2003 | 08:45 PM
Ovaltine's Avatar
Default Re: for the big boost heads (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
I've used a ton of injectors in the past and never had any problems with any of them EXCEPT for RC. I've had 7 sets of rc's go bad...</TD></TR></TABLE>
RC's seem to be very popular, what do you recommend?
Old Jul 31, 2003 | 08:55 PM
tony1's Avatar
Default Re: for the big boost heads (Ovaltine)
The rc's below 550 are OK, not great, but fairly reliable. I've had good luck with greddy, msd, bosch, and precision injectors.
Old Jul 31, 2003 | 09:04 PM
bambooluv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">good luck with greddy, msd, bosch , and precision injectors. </TD></TR></TABLE>
Thank god...... Hey are the bosch's only available in brown and black like the ones I had at your shop just amking sure?-pete
Old Jul 31, 2003 | 09:10 PM
ladysman's Avatar
Default Re: for the big boost heads (bambooluv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambooluv &raquo;</TD></TR><TR><TD CLASS="quote">
Thank god...... Hey are the bosch's only available in brown and black like the ones I had at your shop just amking sure?-pete</TD></TR></TABLE>
I have 800cc RC's and have zero problems. They are Bosch by the way.
Old Jul 31, 2003 | 09:19 PM
tony1's Avatar
Our bosch are blue/black
rippinitup01
Mar 2, 2007 06:46 AM
SpeedingHatch
Dec 31, 2005 02:41 PM
accordselux
Jul 6, 2004 11:21 AM
turbo*s2k
Feb 25, 2004 11:50 AM
Cyber ITR
Dec 18, 2002 05:14 AM
