SUPERCHARGING: Boost Timing Controller and MAP Controller question...
Old Jul 29, 2003 | 09:40 PM
xsnrgsr
Guest
Posts: n/a
Default SUPERCHARGING: Boost Timing Controller and MAP Controller question...
How badly (if at all) would I need a BTC or MAP controller if boosting over 6psi (like 8 or 9 psi)? And why do I NEED them?
Old Jul 29, 2003 | 09:45 PM
keebler65's Avatar
Default Re: SUPERCHARGING: Boost Timing Controller and MAP Controller question... (xsnrgsr)
you'll need the BTC if you dont want to loosed power. the BTC is used so that you can use stock timing until boost kicks in, at which point the timing is gradually retarded proportionate to boost. so the BTC is basically keeping you from loosing power.
the map controller depends on how you're doing the fueling....if you're using an FMU like what JR supplies, then the map mod will be needed to prevent tip-in detonation. however if you're using larger injectors along with a VAFC or SMC then you will have no need for the map controller.
Old Jul 29, 2003 | 10:10 PM
PHiZ's Avatar
What's "tip in detonation", I'd love to read more about related topics, thanks.
-PHiZ
Old Jul 29, 2003 | 10:34 PM
keebler65's Avatar
Default Re: (PHiZ)
its when you first step on the throttle, the motor will ping because there is not enough fuel at first.
Old Jul 31, 2003 | 12:09 AM
xsnrgsr
Guest
Posts: n/a
Default Re: (keebler65)
What about a J&S Safeguard unit? Would it replace anything?
Old Jul 31, 2003 | 01:38 AM
John_at_J&S's Avatar
Default Re: (xsnrgsr)
In addition to boost retard and knock retard, the J&S includes an adjustable MAP Limiter, and TPS modifier.
Here's a link to the install diagram:
http://www.jandssafeguard.com/HondaInstall.html
importparts.com has great prices on them.
Old Jul 31, 2003 | 04:50 AM
92sleepR's Avatar
New User
You won't need EITHER of them if you use a Hondata S200B and its about the same cost. The Hondata can be tuned to pull timing in relation to boost (and the base maps do exactly that)
Above the stock boost though you will need SOMETHING to do whats been described in the posts above.
I have a J&S classic just to be safe but I think it pulls a little too much timing at high RMP because its hearing valvetrain noise.
Mike
Old Jul 31, 2003 | 06:38 AM
Pfieff's Avatar
If boosting that much, I would spend the money on the hondata s100b unit. You can get it for $400. Well worth the money.
Brandenvtec719
Apr 11, 2018 06:58 PM
97grnrs
Jan 9, 2008 09:57 AM
