Nitrous do's and dont's ????
Old Jul 29, 2003 | 10:50 AM
honkey2fly's Avatar
Default Nitrous do's and dont's ????
Ok before anyone says anything I did a search and couldn't find anything on what I am looking for. Basically what are the do's and don'ts of useing nitrous? I'm planning on running a zex 55 shot with zex 2 step colder plugs. Is there anything else I need to know? I heard somewhere that you are supposed to reset your ecu? Is this true? here's what i have basically
Do's:
- get colder plugs
- retard your timing by 2 degree's after a 55 shot
don't:
-spray in 1rst or 5th gear
- increase your timing at all
Old Jul 29, 2003 | 11:04 AM
laughinxxx's Avatar
New User
Default Re: Nitrous do's and dont's ???? (honkey2fly)
-Don't spray for more than 15 seconds or the coil in your noids might melt.
-Don't retard your timing for a 55 shot
-Do get a purge kit
-Do get a bottle heater
-Do check your plugs for detonation often
-Do spray in 1st
-Do some more research
-Don't blow your motor
-Do a compression test before you install the Zex kit.
Old Jul 29, 2003 | 11:59 AM
redlinegsr's Avatar
Default Re: Nitrous do's and dont's ???? (laughinxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx &raquo;</TD></TR><TR><TD CLASS="quote">-Don't spray for more than 15 seconds or the coil in your noids might melt.
-Do get a purge kit
-Do spray in 1st
**** that pretty much sums it up
Old Aug 3, 2003 | 01:55 AM
marc.ejay-twenty's Avatar
Default Re: Nitrous do's and dont's ???? (redlinegsr)
don't use zex plugs...they are ****. use ngk one step colder plugs. u don't need to go 2 steps colder for a zex 55 shot. btw, zex rates their hp gain from the flywheel whereas NOS/nx rate their jettings for hp gain to the wheel.
Old Aug 3, 2003 | 08:58 AM
wolfsburg2's Avatar
don'y spray in 5th or up a hill, or at low engine speeds.
Old Aug 3, 2003 | 09:13 AM
turbochic's Avatar
Default Re: Nitrous do's and dont's ???? (wolfsburg2)
yeah dont use the zex spark plugs, plus, i didnt think you were supposed to get colder plugs for just a 55 shot
also according to NOS (which i'm more familiar with) they dont recomend any timing alterations until 75 shot and after.
just make sure to always keep bottle pressure at optimal, dont let the pressure get to low=lower shot, higher pressure=bigger shot (kinda)
dont get caught with the bottle in the car hooked up on the street
this is a dry kit? dont much about zex, im more of a NOS and NX fan
Old Aug 3, 2003 | 09:38 AM
laughinxxx's Avatar
New User
Default Re: Nitrous do's and dont's ???? (fmaxturbochic)
Zex makes a wet and dry kit now.
Colder plugs are recommended for a 55 shot. Some people get away without them, but some don't. It's just a safety precaution and a cheap one at that.
XzIpK
May 13, 2007 07:16 PM
8891hatchs
Jun 14, 2004 07:27 PM
91hob20hb
11
Jan 8, 2004 12:03 PM
tmekjian
Jun 11, 2003 11:35 AM
BEEFEDUPACCORD
Jan 30, 2002 11:39 AM
