clipping a turbo
Old Jul 29, 2003 | 05:19 PM
ludelvr's Avatar
Default clipping a turbo
Does anyone know the procedure for clipping a turbo? I am familiar of the basics of it, but which part of the turbine wheel are you actually shaving off??
Old Jul 29, 2003 | 05:53 PM
stierhund's Avatar
Default Re: clipping a turbo (ludelvr)
whats the purpose of that?
im not tryin to be a smartass, im curious
Old Jul 29, 2003 | 05:56 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludelvr &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the procedure for clipping a turbo? I am familiar of the basics of it, but which part of the turbine wheel are you actually shaving off??</TD></TR></TABLE>
From what I have read and been told, again read and ben told is that if you are clipping a turbine wheel then it is too small and your should move up to the next biggest turbine wheel. There are downfalls to clipping and is the incorrect way to try to get more flow. I am no turbo EXPERT so I would rather have Rod from Precision chime in, Geoff from Full Race and also Arturbo should have some info on this as well.
Old Jul 29, 2003 | 07:23 PM
stierhund's Avatar
Default Re: clipping a turbo (Boostfed)
i've always been under the impression that both wheels have to be in perfect balance w/each other... so I would never clip to begin with, or I would take it to a pro if it needed to be done that bad
Old Jul 29, 2003 | 07:27 PM
bottlefedb18c1's Avatar
Default Re: clipping a turbo (stierhund)
I have heard myself that it was take a bit longer to spool but in that case will deliver more top when done to a small turbo.
But i have also have heard it doesnt increase effenceny becouse of the waisted ex gases.
But that is from what i have heard.
If you want more CFM or more top end go with a larger size turbo i think.
Steve
zakura R
Jun 19, 2010 10:44 AM
spoolin turbo s
Aug 27, 2008 10:19 PM
DCshoecompany
Jul 18, 2008 05:11 PM
pauld
May 23, 2007 10:31 PM
MugenGSR2001
Feb 8, 2005 04:47 PM
