please help me cant boost
Old Dec 4, 2003 | 02:57 PM
carburatedb18c's Avatar
Default please help me cant boost
I have a turbocharged 89 civic with a gsr motor in it.Its running a T3/T4 turbo with a drag manifold and its intercooled. I im using a vortech fmu and rc 310cc injector for fuel management . The ecu im using is a pr3 and im currently boostin 7 pounds. Timing is stock but im using a msd 6al with the boost timing retard
The car will not boost with the pr3 ecu. It feels like it starts to detonate once it hits vtec. But when i plugged in a ls ecu the car boost fine.I can take it all the way to redline. They are also no check engine light codes
Old Dec 4, 2003 | 03:08 PM
TeStUdO's Avatar
Default Re: please help me cant boost (carburatedb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carburatedb18c &raquo;</TD></TR><TR><TD CLASS="quote">I have a turbocharged 89 civic with a gsr motor in it.Its running a T3/T4 turbo with a drag manifold and its intercooled. I im using a vortech fmu and rc 310cc injector for fuel management . The ecu im using is a pr3 and im currently boostin 7 pounds. Timing is stock but im using a msd 6al with the boost timing retard
The car will not boost with the pr3 ecu. It feels like it starts to detonate once it hits vtec. But when i plugged in a ls ecu the car boost fine.I can take it all the way to redline. They are also no check engine light codes </TD></TR></TABLE>
What does your boost guage say???
Old Dec 4, 2003 | 03:20 PM
Default Re: please help me cant boost (TeStUdO)
7 ponds
Old Dec 4, 2003 | 03:28 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carburatedb18c &raquo;</TD></TR><TR><TD CLASS="quote">7 ponds</TD></TR></TABLE>
So then you are running 7 lbs. with each ECU?? If so just use a P72 or P28
Old Dec 4, 2003 | 03:31 PM
yeah its at 7 for both ecus . I cant run the obd 1 ecus yet need to convert it
Old Dec 4, 2003 | 05:24 PM
Johnyquest's Avatar
so use an LS ecu
crxb16a90
Engine Management and Tuning
Aug 17, 2009 08:57 AM
R6E6I6D
Dec 10, 2005 10:06 PM
DohcVtecCrx
May 16, 2004 06:40 PM
KJ
Jul 2, 2001 07:54 AM
