gsr cams
Old Dec 4, 2003 | 04:33 PM
redboost10's Avatar
Default gsr cams
will gsr cams be any better than stock ones on a b16a2 if im only running 8-10 psi?
are they really worth it? ive heard theyre better and ive heard they dont do a damn thing.
Old Dec 4, 2003 | 04:47 PM
Del_Slowest's Avatar
Default Re: gsr cams (tgh99si)
Keep the stock ones. And for damn sure make sure you don't get any Type R cams
Old Dec 4, 2003 | 04:48 PM
TurboJesse
Guest
Posts: n/a
Default Re: gsr cams (Del_Slowest)
b16a cam<GSR cams<ITR cams
you can find gsr's cheap though
Old Dec 4, 2003 | 04:50 PM
redboost10's Avatar
Default Re: gsr cams (Mpir3)
ive been reading about gsr cams in the b16a2 all night long and it sounds like not a big difference but do it if you got the extra money.
i was just a little concerned cause i read that the gsr cams are a better choice only on the first gen b16a.... got any say in this?
do the type r cams have too much duration for boost?
Old Dec 4, 2003 | 04:55 PM
TurboJesse
Guest
Posts: n/a
ive seen some people gain like 8whp just throwing in GSR cams, not bad if you can find the cams for like 50-70 bucks
Old Dec 4, 2003 | 05:07 PM
redboost10's Avatar
so would i just use the b16a2 cam gears on the gsr cams?
Old Dec 4, 2003 | 05:17 PM
_jester_'s Avatar
Yep, i just installed GSR cams in my b16- no dyno to compare to though
Old Dec 4, 2003 | 05:19 PM
redboost10's Avatar
Default Re: gsr cams (XratedSi)
does it idle any different? might be a dumb question but just curious
Old Dec 4, 2003 | 05:24 PM
alpha's Avatar
Hondata or AEM EMS + GSR or ITR camshafts = Good gains and a Honda like idle. I have bought GSR camshafts for $40.00. That's well worth an 8whp 1 ft-lb gain (I have seen three dyno sheets that both showed 8whp gains on two different setups). I will be using a GSR intake and an ITR exhaust camshaft.
Old Dec 4, 2003 | 05:26 PM
redboost10's Avatar
Default Re: (0x64)
thanks to all for the info about these cams. gsr cams with b16a2 gears sounds pretty good to my ears now, haha.
Old Feb 24, 2004 | 01:10 AM
1SlowSi's Avatar
Default Re: (tgh99si)
What RPM are the GSR's good for? and this may be a dumb *** question, but can you max out a gear before you even redline? vise versa, redline before maxing out a gear?
Old Feb 24, 2004 | 01:40 AM
rocket256's Avatar
Default Re: (1SlowSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">What RPM are the GSR's good for? and this may be a dumb *** question, but can you max out a gear before you even redline? vise versa, redline before maxing out a gear?</TD></TR></TABLE>
They are good for 8100 rpm. But they should peak about 76k-78k.
Old Mar 9, 2004 | 05:55 AM
2k1_ITR_0736's Avatar
Default Re: (rocket256)
holy **** 76k? wow that ssome crazy ****. thats like f1 car revs times 7
Old Mar 9, 2004 | 06:02 AM
type Gendy's Avatar
Default Re: (2k1_ITR_0736)
WEll since we already got the back from the dead here .....
How did you make out tgh99si......did you do the cams? feedback?
Old Mar 9, 2004 | 07:04 AM
redboost10's Avatar
Default Re: (sick hatchem)
im planning on gettins some cams but not til this summer, i will be dynoing my car in about two weeks at 8 psi or 7.25, the tial wg spring.
Old Mar 9, 2004 | 07:09 AM
Turbo92Si's Avatar
good luck tgh99si, let us know what your numbers are when u get back from the dyno.
Old Mar 9, 2004 | 07:31 AM
redboost10's Avatar
Default Re: (Turbo92Si)
thanks man, i will, heres my setup that no one responded to, i was just wondering what you guys think ill make at 8 psi.
https://honda-tech.com/zerothread?id=792317
wearyfurball
16
Feb 19, 2008 08:54 AM
99B16Si
Apr 10, 2006 04:28 AM
civic1234
10
Mar 31, 2006 03:30 PM
CBURKE
14
Dec 15, 2005 09:21 AM
