Nitrous lines
Old Dec 3, 2003 | 07:31 PM
BolivianDc2's Avatar
Default Nitrous lines
Does anybody know if lines like these can take small shot of nitrous?
http://store.summitracing.com/...image
Could these lines be used before the solenoid? after the solenoid?
no flames unless u know fellas
Old Dec 3, 2003 | 07:37 PM
TOFU.man's Avatar
Default Re: Nitrous lines (Bolivianstrtwpn)
uhh i would <U>not</U> go with that that looks like a boost or vacum gage line and hook up and those lines break all the time.
Old Dec 3, 2003 | 07:44 PM
SOHCArchangel's Avatar
Default Re: Nitrous lines (B16AHondaSi)
you have to use extruded teflon lines with crimped fitting ends, and or high press poly lines
just fyi...el cH34p0 n20 setup = b00m, mmmk?
Old Dec 3, 2003 | 09:13 PM
baphomet's Avatar
Default Re: Nitrous lines (SOHCArchangel)
I thought I was skimping with the zinc plated steel ends
Old Dec 3, 2003 | 09:18 PM
integranator's Avatar
Default Re: Nitrous lines (slashDEVslashNULL)
u think that little line will take 900 pounds of pressure?? You let me know. if so, you're sitting on a gold mine and I want a piece.
Old Dec 3, 2003 | 09:40 PM
Default Re: Nitrous lines (integranator)
If you use a jet at the solenoid, would using these lines be that bad for the line from the solenoid to the nozzle?
I could understand the importance of a teflon/ss line from the bottle to the solenoid, but I don't see why you need one from the solenoid to the nozzle if you use a jet at the solenoid.
Old Dec 3, 2003 | 11:33 PM
rOby's Avatar
LOL
dont do that
Old Dec 4, 2003 | 06:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bolivianstrtwpn &raquo;</TD></TR><TR><TD CLASS="quote">If you use a jet at the solenoid, would using these lines be that bad for the line from the solenoid to the nozzle?
I could understand the importance of a teflon/ss line from the bottle to the solenoid, but I don't see why you need one from the solenoid to the nozzle if you use a jet at the solenoid.</TD></TR></TABLE>
Dood, use your brain. Okay, so b4 the solenoid its at (usually) 900psi-ish. As soon as you open up that solenoid all that 900psi of nitrous is just waiting to get out of that whole, and you're going to place a jet in front of it?! then that little baby line, that cracks if you bend it too hard?!?! The line will never hold up-- just forget about it. The pressure is going to be constant throughout the system, until it dumps it into the intake stream--- and going to an even smaller tube will make the pressure greater.
Old Dec 4, 2003 | 06:17 AM
quikB18B's Avatar
Sounds like the line already busted and somehow leaked into the car
Sorry but that line isnt going to work.
Old Dec 4, 2003 | 07:21 AM
Default Re: Nitrous lines (quikB18B)
i'm gonna try it out, see if it works.
thanks for the input, it really was helpful
Old Dec 4, 2003 | 07:30 AM
Finest's Avatar
Not only do you need a line that can withstand 1100psi of pressure, but you also need a line that can withstand SUBZERO temperatures! I don't think that nylon vacuum line can withstand repeated exposure to subzero liquid/gases before breaking. Heck, it can't even bend beyond a 90 degree angle before cracking.
Use what's supplied in the kit. If you're trying to be sneaky, cover the stainless lines with black silicon hoses.
Old Dec 4, 2003 | 07:39 AM
Default Re: Nitrous lines (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Use what's supplied in the kit. If you're trying to be sneaky, cover the stainless lines with black silicon hoses. </TD></TR></TABLE>
i'm making my own kit right now, I thought maybe these lines could be used as an option for a small shot, but it looks like the extreme temp. and pressure they just won't hold up
Old Dec 4, 2003 | 07:42 AM
as long as we're on the subject, I have a custom bottle, and a nos cheater solenoid, what fittings and lines do you all suggest to finish off the kit? I don't know the bottle opening size.
aj99si
Apr 27, 2005 04:44 PM
RTE117
25
Mar 20, 2004 12:54 PM
275Performance
Feb 11, 2004 01:06 PM
dumbkid
Feb 18, 2003 03:48 PM
fastludeh22
Nov 25, 2002 06:29 AM
