AEM FPR drain back fitting help.
Old Dec 2, 2003 | 04:39 PM
5thgencivic's Avatar
Default AEM FPR drain back fitting help.
I was wondering what drainback fitting I should use in my AEM fuel pressure regulator? I bought it used and it didn't come with instructions. I'll be running a walbro 255 and probably stock rail pressure. around 300whp on 550cc injectors. Should I use the big, medium or small opening fitting? Thanks for any help.
Nate
Old Dec 2, 2003 | 04:51 PM
PM-Performance's Avatar
Default Re: AEM FPR drain back fitting help. (5thgencivic)
use at least the medium with the 255lph .
something about the smaller one with more pressure from the bigger pumps causes diaphram flutter and missfires, mine did that and drove me nutts for a while until i got on the phone with AEM , he told to me switch that and worked like a charm since.
Old Dec 2, 2003 | 05:52 PM
Default Re: AEM FPR drain back fitting help. (itr206)
ok, thanks. The biggest one is in there now. Not sure if I should swap it out to the medium or not..
Old Dec 2, 2003 | 05:56 PM
youll prob be fine with it , thos ebigger fittings have to do with fuel pressure thue the fpr, and the smaller the fitting the more you will need to turn the set screw in to lower the pressure from what i remember and it causes the diaphram to flutter becuase it tries to clamp down on it too much or something , i forget how to explain it
Old Dec 2, 2003 | 05:57 PM
b16ahybrid's Avatar
If it's working fine, leave it in there.
using the largest one with my fpr, I'm also runing a holley 255lph intank pump.
Old Dec 2, 2003 | 06:00 PM
Default Re: AEM FPR drain back fitting help. (b16ahybrid)
Haven't put it on yet so not sure how it works. I'll probably just try the big one. thx guys
5thgencivic
Feb 3, 2004 01:48 PM
turbochic
May 15, 2003 06:29 PM
dochmees
Nov 21, 2002 12:16 PM
Malice
Mar 31, 2002 04:48 PM
