Greddy Front Mount - NEED help!!
Old Dec 4, 2003 | 04:09 AM
RedTegLS's Avatar
Default Greddy Front Mount - NEED help!!
Hey everybody! I tried to mount my greddy type 31 last night and it looks like the pipe that comes off the upper charge pipe is not going to line up with the IC outlet. Has anyone had to modify there charge pipe that comes of the TB to fit the Greddy kit? My turbo kit is not a greddy is that why its not lining up? The pipe that comes off the turbo and wraps around to the inlet is fine. Do you mount it with the endtanks up or down? Does it matter? Sorry for all the questions but I am trying to get it done! Thanks!!
Old Dec 4, 2003 | 06:05 AM
APEX i GSR's Avatar
Default Re: Greddy Front Mount - NEED help!! (RedTegLS)
i had to modify all the piping on one i got
the end tank inlets are towards the bottom
Old Dec 4, 2003 | 06:23 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote"> My turbo kit is not a greddy is that why its not lining up? !!</TD></TR></TABLE>
That would be a good start.
Old Dec 4, 2003 | 06:33 AM
RedTegLS's Avatar
Default Re: Greddy Front Mount - NEED help!! (b16ahybrid)
As much as I appreciate your sarcasm, how many people actually have the Greddy turbo kit that use a Greddy IC kit?
Old Dec 4, 2003 | 06:54 AM
AVATAR's Avatar
I have the type 31 on my 00Si, there wasnt any modification to the pipes or car itself (other than trimming the **** outta the fender liner so that the flipped U-pipe could connect).
Old Dec 4, 2003 | 04:53 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">As much as I appreciate your sarcasm, how many people actually have the Greddy turbo kit that use a Greddy IC kit? </TD></TR></TABLE>
That actually wasn't sarcastic. But being that you pointed out that your not using the greddy kit ( which includes pipes bent for the greddy intercooler) with the greddy intercooler I figured that I would point out that your problem may be related to that.....
I'm using the greddy intercooler with my set-up, but decided to weld a new endtank instead of routing the pipes all over the place...
Old Dec 4, 2003 | 05:19 PM
Johnyquest's Avatar
It's really easy to get the pipe through there, all I did was cut a big X through the black **** under teh winshield washer resoviour big enough to push the pipe through... The other side should be easy...
Old Dec 4, 2003 | 06:38 PM
RedTegLS's Avatar
Default Re: Greddy Front Mount - NEED help!! (Johnyquest)
Hey, I got it in and running! thanks everybody.
Old Dec 4, 2003 | 07:17 PM
Chiovnidca's Avatar
I do. Everything fit perfect. I was impressed.
youryanyou
Mar 14, 2010 01:32 AM
bootlegcivic
Apr 4, 2008 07:32 AM
ktran1
Jul 19, 2004 06:26 AM
bluebullet
Mar 15, 2004 08:48 PM
