stutter at part throttle wtf????
Old Dec 2, 2003 | 11:24 PM
hybridb18's Avatar
Default stutter at part throttle wtf????
My car has a bad stutter when i try to keep it at a constant speed. it happens right when i get back on the throttle lightly. But if i push the gas to the floor, it doesnt stutter at all. its only when im lightly pushing the gas trying to keep a constant speed.
BTW heres the setup
ls motor, drag turbo kit, safc, dsm 450's, msd digital 6 plus ignition, and coil, ngk BCPR7ES11 plugs.
UMMMMMMMMM, the car is completely tuned, ignition is retarded like 3 degrees, but theres no vaccume leaks.
It is really bad when im using the cruise control, the car jerks back and forth.
Anyone got any idea, or similar problems???
Old Dec 2, 2003 | 11:26 PM
Mr. Softee's Avatar
Default Re: stutter at part throttle wtf???? (hybridb18)
check your throttle cable
Old Dec 2, 2003 | 11:45 PM
hybridb18's Avatar
Default Re: stutter at part throttle wtf???? (94goldjungsr)
hmmm, never thought of that. The pedal doesnt seem to get stuck though. i think it has something to do with the afc hack. i wonder if anyone else running the hach has this problem
Old Jul 31, 2004 | 07:24 PM
InLimbo87's Avatar
back from the dead. i have the same exact problem. could i be in the need of spark plug gapping?
Old Jul 31, 2004 | 07:27 PM
twkdCD595's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridb18 &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, never thought of that. The pedal doesnt seem to get stuck though. i think it has something to do with the afc hack. i wonder if anyone else running the hach has this problem</TD></TR></TABLE>
I heard rumors of this problem being not fixable, something about the vaccum at part throttle like that and the motor actually cutting the injectors off for a second for fuel efficiency or something.
I forgot the details but I remember reading it over at pgmfi... j davis I am sure among others have also seen this... hopefully someone else can elaborate more surely.
will look for the thread over there though agian and try to link it.
Old Jul 31, 2004 | 09:08 PM
tegmech's Avatar
when will people ever learn to quit using the damn hack. Get uberdata, hondata, whatever. Ditch that pos and get something worthwhile. Especially since uberdata is free(minus chip, burner, wideband)
Old Jul 31, 2004 | 09:50 PM
Mag00n's Avatar
Default Re: (tegmech)
Check your settings on the hack.
Old Jul 31, 2004 | 10:19 PM
SC61HB's Avatar
Mine did the same thing, and I was using Hondata (S200B)
Old Jul 31, 2004 | 10:22 PM
xratedpres's Avatar
I had the same problem with my hodnata s100.
You can tune it out. I found some issues happening like that when my distributor was going out on me. so check the voltage on that sometime.
Also check your base timing. and do a boost leak test as well. Sometimes higher vac leaks can cause a strange condition. I know exactly what you are talking about.
Old Aug 1, 2004 | 06:23 AM
Oyvind Ryeng's Avatar
Just to be sure, hook up a voltmeter to the TPS-sensor. From what I've heard a bad TPS-sensor/bad connection can cause these kinds of symptoms.
Old Aug 1, 2004 | 08:26 AM
drvfast's Avatar
Its common when running the hack.
arospeedintegra
May 30, 2008 01:20 AM
all_motorsi
May 11, 2007 11:46 PM
mr poo
15
Jun 14, 2006 08:09 PM
handa
12
Dec 8, 2004 08:39 PM
Suzukablue
Jul 24, 2003 03:21 PM
