ARP head studs????
Old Dec 3, 2003 | 03:17 AM
BoostedD15B7's Avatar
Default ARP head studs????
When using the ARP headstuds, do you still need to use the two dowel pins?
Old Dec 3, 2003 | 04:10 AM
genop's Avatar
Default Re: ARP head studs???? (BoostedD15B7)
Why wouldnt you want to use the dowel pins?
Old Dec 3, 2003 | 06:13 AM
yellowturbo's Avatar
you should do ... why not ??
Old Dec 3, 2003 | 07:54 AM
BROOD's Avatar
Default Re: (yellowturbo)
Yes, you still use the dowel pins. Just make sure to check dowel height against the dowel hole depths before bolting it together.
If the dowels are too long, grind them down to the correct height. You do not want them impeeding the cylinder head from seating to the block correctly. (more noticable if the deck and cyl face have been surfaced/milled)
Old Dec 4, 2003 | 03:31 AM
Default Re: (BROOD)
hmmm. well mine arent in.. when the motor was built we forgot to put them back in. That why im wondering if its throwing off my gasket and head alignment just a hair and causing the detonation problem im having. Maybe the gasket is off a **** hair and hangs just into the cylinder. The metal ring may cause detonation. This sound stupid or can it happen? My timing is WAY back. Plug good, wires good, cleaned rotor and cap dont know what the hell is causing it.
Old Dec 4, 2003 | 03:46 AM
danl's Avatar
Banned
Default Re: (BoostedD15B7)
Yes, that is one of the primary reasons those dowell pins are in their, to line up the headgasket and more particullar the head.
Old Dec 5, 2003 | 03:22 AM
Default Re: (danl)
anyone else have opinions? this my detonation problem? i hate to pull the head if thats not the problem
Modified by BoostedD15B7 at 11:53 PM 12/6/2003
jthrasher1
May 23, 2010 12:20 PM
Tuner Eddy
Feb 18, 2008 09:23 PM
slvrcvc93
May 16, 2007 07:32 PM
97gsrki
Oct 13, 2006 12:42 PM
staticrex
Jan 23, 2004 01:39 PM
