turbo vaccum
Old Dec 4, 2003 | 06:42 PM
CaptainMorgan's Avatar
Default turbo vaccum
I notice that a boost controller is hooked in to the vaccum port on the compresser side of the turbo. I notice that my garrett t3/t4 4bolt does not have that vaccum port. How do I hook up an boost controller if it doesn't have this port?
Old Dec 4, 2003 | 06:44 PM
redboost10's Avatar
Default Re: turbo vaccum (doubler)
top of the wastegate im pretty sure
i got the lines confused, sorry
Old Dec 4, 2003 | 06:46 PM
hooohaa2's Avatar
you can run it off of any vacuum source. It doesn't need to be off of the turbo. I don't know what engine you have, but you can use the cruise control vacuum feed as a source. Also, you have a vacuum line running to your fuel pressure regulator. Just use one of those. Let us know how it goes.
Old Dec 4, 2003 | 06:50 PM
booscivic's Avatar
maybe this will help, a vaccum manifold will help keep everthing in place!
Old Dec 4, 2003 | 06:58 PM
So i can run a 3 way T, off the intake manifold and beable to run the bov, boost controller, and wastegate. So Any engine vaccum will work?
Old Dec 4, 2003 | 07:08 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubler &raquo;</TD></TR><TR><TD CLASS="quote">So Any engine vaccum will work?</TD></TR></TABLE>
Yes
Old Dec 4, 2003 | 07:11 PM
Ri5e's Avatar
Default Re: turbo vaccum (TeStUdO)
The hole on the turbo is a boost source, not a vacuum source. If you don't have one, you can just drill a hole and tap one.
Old Dec 4, 2003 | 10:59 PM
If it is a boost sourse then how does the boost gauge work off vaccum? If i really have to tap the compresser end, can i just tap into the my charge pipes. Its so much harder to tap into a cast iron then a SS pipe.
Old Dec 4, 2003 | 11:38 PM
GPoodle
Guest
Posts: n/a
It doesnt matter where you drill a hole in the entire system. It will be either a boost source, or a vacuum source, but not both. Therefore the hole on the turbo is both a boost and vacuum source, and a good place to tap.... though for a gauge, its best to T one of the vacuum lines comming off the manifold (preferably the brake booster) since theres a loss of air pressure through the intercooler, and any leaks you may have. Using the compressor housing as a vac/boost source would give less accurate numbers.
Old Dec 5, 2003 | 12:53 AM
Dee's Avatar
Dee
Default Re: (GPoodle)
Dammit ! I was hoping to see a boosted HOOVER
1cammerjammer
Oct 22, 2009 10:04 PM
GOIN V8 HUNTIN
Dec 12, 2006 05:17 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
1boostedcivic
Sep 1, 2005 06:05 PM
redhatchb18
Oct 7, 2003 02:26 PM
