car wont stop boosting?
Old Dec 6, 2003 | 12:47 PM
xXx Justin xXx's Avatar
Default car wont stop boosting?
96dx, y8 IM, greddy kit. there is no nipple for vacuum on the turbo. and i have a MBC hooked up that I KNOW WORKS. never stops boosting. tried the controller both ways.. switched the vacuum source.
then we ran open waste gate actuator... figured it would run the spring. i let off when it didnt stop by .75 bar....... and that = about 11psi... anybody have any guesses?
Old Dec 6, 2003 | 01:07 PM
InTeGrA B18b1's Avatar
Default Re: car wont stop boosting? (SOHC Beast)
either the wastegate vacuum line is clog or your mbc is on backwards or your wastegate is stuck closed.
Old Dec 6, 2003 | 01:13 PM
Default Re: car wont stop boosting? (InTeGrA B18b1)
anyway to test if it is stuck closed other than removing the turbo... leki take the actuator arm loose or something? thanks alot for the help
Old Dec 6, 2003 | 02:25 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast &raquo;</TD></TR><TR><TD CLASS="quote">96dx, y8 IM, greddy kit. there is no nipple for vacuum on the turbo. and i have a MBC hooked up that I KNOW WORKS. never stops boosting. tried the controller both ways.. switched the vacuum source.
then we ran open waste gate actuator... figured it would run the spring. i let off when it didnt stop by .75 bar....... and that = about 11psi... anybody have any guesses?</TD></TR></TABLE>
open actuator? it still has to have a boost reference going to it to run off the spring preset.
Old Dec 6, 2003 | 07:42 PM
Default Re: car wont stop boosting? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
open actuator? it still has to have a boost reference going to it to run off the spring preset.</TD></TR></TABLE>
ok..thats what i thought too.... which end of the MBC is supposed to lead to the acuator.. and where do you recomend going for vacuum source? officially so i can try this. i had it T'd in with the bov, and run from the cruise control nipple on the back of the intake manifold. had the bottom(straight under spring) running from vacuum source... the middle running to the acuator...
Old Dec 7, 2003 | 06:34 AM
Old Dec 7, 2003 | 09:11 AM
norcalcrx's Avatar
Does it work without the mbc hooked up? Just running a line from the nipple on the wastegate actuator to a vacuum source?
Old Dec 7, 2003 | 12:15 PM
Default Re: car wont stop boosting? (norcalcrx)
havent tried.... what should it boost running like that?
Old Dec 7, 2003 | 12:22 PM
Cee_mon's Avatar
Take off the MBC and see if it holds at 5.5psi like it is suppose to stock.
Old Dec 7, 2003 | 02:17 PM
Default Re: car wont stop boosting? (Cee_mon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cee_mon &raquo;</TD></TR><TR><TD CLASS="quote">Take off the MBC and see if it holds at 5.5psi like it is suppose to stock. </TD></TR></TABLE>
open actuator...or solid line to the manifold?
Old Dec 7, 2003 | 03:11 PM
integra_gsr98's Avatar
Hook a vacuum line from the WG actuator to a vacuum source on the motor somewhere. Does it run 5.5 psi? If so, your wastegate is working fine.
Next, reinstall the boost controller, and open it completely. You should get zero restriction and run 5.5 psi.
After that, begin tightening the boost controller until you impose a restriction on the pressure going to the wastegate actuator. Adjust this until your boost is set where you want it.
Old Dec 7, 2003 | 03:34 PM
Default Re: car wont stop boosting? (integra_gsr98)
ok... hooked a line from actuator to IM... runs exactly .4bar... which i think is closer to 5.8psi....close enough. now... which way does the MBC go? which side goes to the actuator, which goes to the IM. thanks for all of the help guys.
Old Dec 7, 2003 | 04:19 PM
norcalcrx's Avatar
Usally depending on what mbc you use, The nipple on the bottom goes to the vacuum source and the nipple on the side goes to the wastegate. This is how it works on the turboxs mbc. http://www.turboxs.com look in there FAQ for hooking one up.
Old Dec 7, 2003 | 04:55 PM
yea..... what type of clamps do you all use. i keep blowing off the pipe from the turbo bc it was cut.. there is no lip on it anymore.. regular clamps cant get tight enough to hold it.. they end up stripping.
anybody know where i can buy the clamps that have a nut and bolt ( like stock clamp at TB) ? the kind that have a nut/bolt instead of screw...
nm, a friend gave me this link!! http://www.hosetechniques.com/
Modified by SOHC Beast at 2:05 AM 12/8/2003
b18vtec
Nov 24, 2008 08:31 AM
The Dirty EJ1
Jun 10, 2007 02:31 PM
HybridKOOP
Oct 15, 2005 09:30 AM
Blazin Civic
Mar 7, 2005 10:49 PM
turbob16
Dec 28, 2003 03:00 PM
