golden eagle fuel rail questions....
i have a jdm b16a and am running a 35 shot NX single-fogger wet system. I'm doing some fuel system upgrades right now to up the N20 shot and be prepared for turbo by the summer. I have a Walbro 255lph HP fuel pump and an Aeromotive 13109 fuel pressure regulator at my house waiting to be installed. I want to install the FPR and the fuel rail at the same time. I didn't order the fuel rail yet but i will be getting the Golden Eagle one. What size inlet/outlet fitting combination should i order?
It was mentioned here https://honda-tech.com/zerothread?id=412599 to make sure you order the right size.
BTW, I want to mount the Aeromotive FPR right on the fuel rail along with a fuel pressure gauge. I will be boosting around 275whp to start and eventually when the engine is built, over 400whp. hope someone can help. thanks in advance.
oh yeah, heres the link on GE's website to the fuel rail: http://www.goldeneaglemfg.com/street.html
-rob
-rob
Re: golden eagle fuel rail questions.... (sol2nr)
Isnt the inner and outer bore diameter -8? You could do fittings for -6/-8. Also if you want the fiting to mount the FPR on the rail talk to Flamenco-T, I think he has em stocked now. I should be getting my lines and fittings tomorrow and my set up will be exactly the same as yours.
Re: golden eagle fuel rail questions.... (AVATAR)
"-Precision CNC machined from 6061T6 billet aluminum
11/16” ( .6875 ) fuel bore for maximum fuel delivery on street or full race alcohol burning engines
- -8AN O-ring ( Boss ) ports provide huge flow capability
-Utilizes two ( 2 ) 1/8 NPT ( pipe ) ports for fuel pressure gauge or fuel pressure sending unit. Also comes with two ( 2 ) 1/8” NPT plugs
-Allows use of stock fuel pressure regulator
Comes with stock Banjo fitting adapter and plug for “bolt-on” applications
-Optional fittings:
- -6 AN fitting Part# GAN100-6
- -8 AN fitting Part# GAN100-8
- -10 AN fitting Part# GAN100-10"
thats from GoldenEagle's site.
so i guess it comes w/ -8 AN inlet and outlets which can be sized down to -6 and custom made to -10 ???
-Optional fittings:
prodragEG
Northwest (Sales)
09-19-2008 12:50 PM
Bantam
03-07-2003 08:58 AM
