Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata?
Old 12-03-2003, 04:17 PM
Osokwik's Avatar
Default Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata?
I'm looking into the Full-race setup and I wanted to see if I could get away with useing it on stock internals w/o problems. I have the Hondata S200 w/ 3 step already. I know that it would be a good idea to get the boost option for it, but besides that, what else should I get to run a "safe" Full-race setup?
Things I already have:
- Hondata S200 and IM gasket
- '99 spec. ITR valvetrain, cams, IM, and TB
- Fluidyne radiator
- Fal fan
- Oil cooler
- Moroso oil pan
- Oil temp., oil press., EGT, and water temp. gauges
- Greddy Evo. exhaust (I know their O.K., but I bough it 3 years ago....)
- Walbro 255 fuel pump
The rest is all stock. I hope you guys can point me in the right direction .
Modified by Osokwik at 2:25 AM 12/4/2003
Old 12-03-2003, 04:21 PM
Reilly's Avatar
Default Re: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata? (Osokwik)
Yes, just don't get too crazy on boost. You have to get the boost option. I would tune it to around 300fwhp, or more importantly, around 200lb tq. Will be real nice. My buddy just upgraded to a GSR/Full Race, was b16/full race ran 12.4's in a hatch on bfg dr's!
Old 12-03-2003, 04:23 PM
B18PoweredCivic's Avatar
Go for it...Full Race + Hondata = Very serious setup...Just make sure its tuned well..and you get the proper Injectors and fuel pump...
Old 12-03-2003, 05:28 PM
Osokwik's Avatar
Default Re: (B18PoweredCivic)
What about the compression ratio of the stock pistons? Will they be O.K.? What size injecters should I be running with a setup like this? By the way, I'm getting a CM clutch and ACT streetlite flywheel for X-mas. The quaife I'm in the process of getting . The car is in storage for the winter months so I'll have time to work on it. Any other suggestions?
Old 12-03-2003, 05:36 PM
alpha's Avatar
Default Re: (Osokwik)
I would recommend Precision 525cc injectors. That's more than enough fuel for 300whp.
Old 12-03-2003, 05:47 PM
Reilly's Avatar
Compression no problem, you will hit 300hp on pump gas with stock compression. I would get 720's with resistor box, that way you don't have to upgrade later when you build the motor for more hp. I have RC550's now, but will be upgrading later too.
Old 12-03-2003, 07:16 PM
norcalcrx's Avatar
Default Re: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata? (Reilly)
https://honda-tech.com/zerothread?id=691230
If it is setup right it will be fine. Look at Geoff's dyno plot. His #'s are killer and he is on a stock block. I would buy some large injector's and get it tuned. You will definatley need the boost option and if you drag race i would get the 3 step.
Old 12-03-2003, 07:23 PM
Full-Race Javier's Avatar
Default Re: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata? (norcalcrx)
the other Jeff made good power too
https://honda-tech.com/zerothread?id=594948
Old 12-03-2003, 09:14 PM
TurboJesse
Guest
Posts: n/a
Default Re: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata? (Full-Race Javier)
I don't have a full race kit but i made ok numbers for a stock b16, maxed @311whp 212wtq with tubular manifold, t3/to4e 60 trim, hondata s100, etc, boosted hybrid did the tuning Im running inline pro headgaskt to drop comp. ~1pt and arp studs, If you interesed i have an extra 2mm headgasket and Some ARP's for a b16 i need to get rid of, im in Albany too so pretty close
Old 12-03-2003, 09:55 PM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=691230
If it is setup right it will be fine. Look at Geoff's dyno plot. His #'s are killer and he is on a stock block. I would buy some large injector's and get it tuned. You will definatley need the boost option and if you drag race i would get the 3 step. </TD></TR></TABLE>
Is that a gsr or b16 block? He never mentioned it on his post.
Old 12-03-2003, 10:32 PM
TurboJesse
Guest
Posts: n/a
Default Re: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata? (SpdFrk)
i think its a b18 not sure if its a b18b or b18c, it isn't stock block though, stock sleeves is alot different than stock block...Sick numbers though, inspired me to build a b18c1 with stock sleeves
95dxsir2
08-25-2007 02:37 PM
Prudz_lude
05-29-2007 07:01 AM
Elite Hatch
08-25-2002 01:37 PM
Aeka GSR
05-10-2002 09:12 AM
Lei Siew Long
09-21-2001 01:39 PM
Quick Reply: Is it O.K. to run Full-race turbo on stock '99 B16 w/ Hondata?
