B16 block B18c1 head. which pistons?? Which oil pump?
FI motor with JE pistons and Eagle rods. ROds are for B16 I need to know which pistons will work best with GSR head? Pistons will be a dish 9-1 comp ratio.
Also which oil pump to get from Honda. Type-R, GSR or B16 for the B16 block?? Thanks
Sean
Sean
Re: B16 block B18c1 head. which pistons?? Which oil pump? (lbz34)
Anybody know?
I also need a timing belt I would guess it would be the b16 belt right?
endyn pistons and an endyn reworked oil pump. http://www.theoldone.com check it out. A bit more spendy but worth it. Also I'm pretty sure the b16A timing belt but not a 100% hopefully someone will confirm or deny that for us.
Re: B16 block B18c1 head. which pistons?? Which oil pump? (Lucky_Smurf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucky_Smurf »</TD></TR><TR><TD CLASS="quote">endyn pistons and an endyn reworked oil pump. http://www.theoldone.com check it out. A bit more spendy but worth it. Also I'm pretty sure the b16A timing belt but not a 100% hopefully someone will confirm or deny that for us.</TD></TR></TABLE>
yes use the b16 timing belt. Also look into CP pistons. As far as the oil pump goes stock pumps have been known to work exceptionally well, as well as shattering/ another option is the stock oil pump with Pro Drive gears. thats what ill be running in the next setup.
Re: B16 block B18c1 head. which pistons?? Which oil pump? (g2turbo)
I am using Probe pistons. Which piston to use?? THe GSR or the B16? both are available in the 9-1 comp ratio.
Re: (lbz34)
Back from the dead, I'm doing this setup now. I have a gsr oil pump and a b16 timing belt. Now all I need is B-series pistons right(they all the same?)
AnDThEnWuT
Northern California (Sales)
20
04-22-2006 06:13 PM
