Vacuum lines...quality...???
Old Dec 5, 2003 | 11:55 AM
JDubya's Avatar
Default Vacuum lines...quality...???
Will just some regular vacuum lines from autozone work or do I need something better. The ones I picked up today say 6.4mm FUEL/EMISSION SAE 30R7. Are these good enough?
Old Dec 5, 2003 | 01:26 PM
i2un's Avatar
Default Re: Vacuum lines...quality...??? (ALL MOTOR LS)
Vacuum lines a vacuum line. But if it's available try to pick up some silicon vacuum line kit. It's usually a bit thicker and more heat resistant. For like $20 (or so) for a kit, it's a good investment.
Old Dec 5, 2003 | 06:51 PM
JDubya's Avatar
Default Re: Vacuum lines...quality...??? (i2un)
Oh ok, I just noticed that it's easier to pinch some vacuum lines closed than it is others...
Old Dec 5, 2003 | 09:19 PM
AB16A2T's Avatar
Personally, all my vacuum lines, fuel lines, and oil lines, are gonna be braided lines. Nothing half-***, do the best on everything the first time, make it as reliable as possible. There isn't anything like doing something right until you get down to one "minor" detail and that minor details blows your motor, shoots pieces of valve out the manifold destroys the turbo and flushes a couple grand down the toilet.
Old Feb 11, 2004 | 06:56 PM
mskibbz-T's Avatar
Default Re: Vacuum lines...quality...??? (AB16A2T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AB16A2T &raquo;</TD></TR><TR><TD CLASS="quote">Personally, all my vacuum lines, fuel lines, and oil lines, are gonna be braided lines. Nothing half-***, do the best on everything the first time, make it as reliable as possible. There isn't anything like doing something right until you get down to one "minor" detail and that minor details blows your motor, shoots pieces of valve out the manifold destroys the turbo and flushes a couple grand down the toilet.</TD></TR></TABLE>
What brand of braided lines are you using? Do you have any pics? Thanks
Old Feb 11, 2004 | 07:00 PM
5thgencivic's Avatar
Default Re: Vacuum lines...quality...??? (mskibbz-T)
Silicone vacuum tubing seems a little on the soft side to me, but they hold up to the heat well. So that's what I'm using.
Old Feb 11, 2004 | 07:04 PM
int3gra's Avatar
i would choose the flamenco brand lines, the price is great
http://www.fast-turbo.com
Old Feb 12, 2004 | 01:39 PM
rtype11's Avatar
proper vacuum line actually has a vacuum rating, maybe not printed but find the packaging it comes in and check the rating, you need something for redundancy sake in the order of VAC 40"Hg and pressure to 40PSI, if you check MCmastercar they actually rate their lines. fuel line is not meant to be under vacuum therfore their is usually no vac rating, you will never know if it will reduce in diameter/pinch under vacuum.
Old Feb 12, 2004 | 06:25 PM
Rtype16's Avatar
Default Re: Vacuum lines...quality...??? (rtype11)
SAE 30 R7 is a standard for automotive vacuum lines they must hold certain characteristics. That hose should be fine on your car.
Old Apr 12, 2004 | 07:48 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Vacuum lines...quality...??? (Rtype16)
what about using .25" ID fuel hose for vacuum lines? Bad idea?
kyden
Sep 16, 2009 09:11 AM
crazyimport
May 22, 2006 06:18 PM
xci_ed6
Aug 10, 2002 05:35 PM
