HELP! Turbo troubles
Old Jun 19, 2008 | 07:11 AM
Blacklabel182's Avatar
Default HELP! Turbo troubles
HELP!!!!!
i was on the highway this morning in mid-boost and it just sounded off, so i let off the gas. now i dont hear the whine of the turbo spooling as clearly and i dont hear bov either, but the car ran and drove fine the 15 miles home, and it seems like im still getting boost.
I haven't even had my setup for that long yet and I'm kind of in a panic as I have essentially no money if there's a big problem.
Anybody?
Old Jun 19, 2008 | 07:30 AM
turbodano's Avatar
Default Re: HELP! Turbo troubles (Blacklabel182)
Take a look in the inlet of the turbo and see if you see any damage. Also feel the shaft to see how much movment you have in it. The wheel also may have contacted the housing so check for that also.
I know you are low on cash so i will help you as much as I can to get you back on the road.
Pics will help alot.
Old Jun 19, 2008 | 07:47 AM
Default Re: HELP! Turbo troubles (turbodano)
Just got finished on the once over. seems like a rubber hose blew, leading from the intake to the boost controller, it blew right before it gets T'd off, so im gonna replace that, start her up, and see how it goes.
Old Jun 19, 2008 | 07:59 AM
turbodano's Avatar
Should be a simple and no cost fix man. Thank God.
Old Jun 19, 2008 | 10:54 AM
drewrock783's Avatar
i just boosted my sol and now i have a miss fire under 4000 rpm...what could that be? not enough fuel?????? help!
Old Jun 19, 2008 | 11:03 AM
turbodano's Avatar
Default Re: HELP! Turbo troubles (drewrock783)
what are you using to tune the car with? What info can you supply other than it has a miss? Air fuel logs would be great.
Check your plugs.
Old Jun 21, 2008 | 06:26 AM
makes boost fine in first. then half way through second a check engine light comes on and it feels lilke timing is dropping off. I shut the car off and the code is instantly gone. I have a snap on modis but dont know how to get into the honda comp. to scan it. how can i get the car to give me a code?
Old Jun 21, 2008 | 11:10 PM
95dc2teg's Avatar
sounds like you need to get the car tuned. u cant just throw on a turbo and expect it to run right...
4drteg54321
Aug 14, 2010 11:38 PM
andyman97
Dec 28, 2003 01:43 PM
xXx Justin xXx
Dec 4, 2002 09:27 PM
Boosted B18C5
Nov 14, 2002 10:40 PM
Boosted B18C5
Nov 13, 2002 07:07 PM
