dumb question......
Old Jun 10, 2008 | 07:05 PM
motor_man's Avatar
Default dumb question......
ok well im rebuilding my motor and to do it as cheap as possible so i can dyno tune it im having to use itr pistons witch i think are 10.6.1 compression, and i need to find out how bad that could be. its a stock b18c1, 450cc injecters, 255 pump, itll be on 8-10lbs depending on what you guys say. im just kind of flusterd and dont kno what to expect. im sorry and i have serched a little. any info is apreciated.
thanks...
Old Jun 10, 2008 | 07:24 PM
95dc2teg's Avatar
Default Re: dumb question...... (motor_man)
if your using the itr pistons with the gsr head your compression is going to be 10.8:1 or somewhere around there. I had this and pushed 270whp and 210tq all day running 12.7's consistantly with a 2.2 60' . I then decided to bump it up to 306whp and 215tq and it lasted about 4 months till i spun a rod bearing. My motor was also rebuilt with the itr's and gsr head before i boosted it. Did not realize i was running itr's till i tore it apart after the spun rod bearing. I would say stick between 250-280whp and you should be ok and happy (by the way this is from my personal experience and IMO so if you disagree feel free to say you do)
Old Jun 10, 2008 | 07:28 PM
motor_man's Avatar
Default Re: dumb question...... (95dc2teg)
no i dont disagree i dont kno what to expect but thanks for the input.
sh!ft
May 3, 2011 12:30 PM
SOHCunderdog
22
Dec 20, 2009 04:49 AM
:Andrew
15
Sep 18, 2006 01:10 PM
servion
Apr 21, 2003 01:56 PM
JG ENGINE B18C1
Oct 29, 2002 09:06 PM
