Help with precision injectors?
Old Jun 9, 2008 | 05:19 PM
jgrogan's Avatar
Default Help with precision injectors?
I tried to plug the plug from the harness and it wont plug in. I have a 98 integra it is a ls/vtec. Its a 98 gsr head and a 98 ls block. Any help would be great. Oh the injectors are 1200cc precision turbo and engine. Thanks
Old Jun 9, 2008 | 05:45 PM
non-VTEC's Avatar
Default Re: Help with precision injectors? (jgrogan)
you need the OBD1 injector harness clips to plug them in.
the place you bought the injectors should be able to sell you some. even some of the vendors on the board can sell you them.
Old Jun 9, 2008 | 07:07 PM
inspyral's Avatar
You can try doing this as well:
https://honda-tech.com/zerothread?id=1936840
Old Jun 9, 2008 | 07:38 PM
jgrogan's Avatar
Thanks I will look around. I saw something about cutting some tab out of the plug. But I gues that is on the obd1 plug. So when I get the harness I will have to still cut that tab. Thanks again for the help.
Old Jun 9, 2008 | 11:45 PM
da_dude's Avatar
Should of just remover the blue tab in your injectors plug.
Old Jun 10, 2008 | 01:30 AM
mtber's Avatar
Default Re: (da_dude)
Buy your self a set of precision injector clips & install them properly.
JDMequalslife
Jan 22, 2014 06:29 PM
94rs-turbo
Aug 16, 2007 02:04 PM
Civic Racer X 7
Nov 2, 2005 01:52 PM
91lude
Dec 17, 2001 12:51 PM
pregunta
Dec 13, 2001 01:22 PM
