Two Cylinders Running Lean
Old Jun 11, 2008 | 04:47 PM
rdssk8rcs1's Avatar
Default Two Cylinders Running Lean
Went to the dyno last saturday. Started to tune it and realized cylinder 2 and 4 were running very lean. Was also having issues dialing in the A/F ratios. One pull would be good and another one would be lean all the way up. Also, the car is making 100 less whp than it did last year on the same set up. Checked the compression and it was 200-210 across all cylinders.
Any ideas?
The set up is an ls/vtec with a modified rev-hard kit. Tried tuning it off the 15 psi wastegate spring when the issues began.
Thanks in advanced for any thoughts and advice
Old Jun 11, 2008 | 04:55 PM
LA_HONDAS's Avatar
Default Re: Two Cylinders Running Lean (rdssk8rcs1)
soon to be
rdssk8rcs1's Avatar
Default Re: Two Cylinders Running Lean (LA_HONDAS)
Old Jun 11, 2008 | 05:00 PM
LA_HONDAS's Avatar
what ems and injectors
Old Jun 11, 2008 | 05:03 PM
gsrt's Avatar
check the injector filter. might be dirty.
or put more %duty injector on 2 and 4. if your AF change, you need to clean them.
rdssk8rcs1's Avatar
hondata s200 and the injectors are brand new 1000cc rc's with a brand new fuel filter and all new fuel lines
Old Jun 11, 2008 | 05:47 PM
awdgsx96's Avatar
Do the injectors have the right harness running to them?
My friend's boosted GSR was giving him problems the other day with idle and WOT. Injectors 2 and 3 had misplaced plugs, he switched them around and the car was fine after.
Just my .02
Old Jun 11, 2008 | 05:53 PM
LA_HONDAS's Avatar
Old Jun 11, 2008 | 05:57 PM
rdssk8rcs1's Avatar
Default Re: Two Cylinders Running Lean (awdgsx96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">Do the injectors have the right harness running to them?
Just my .02</TD></TR></TABLE>
Good thought. It is a possibility, since last season i converted the car to rhd and did a wire tuck, so i very possibly could have botched them up. Thanks.
Any other thoughts?
Old Jun 11, 2008 | 09:16 PM
rdssk8rcs1's Avatar
anyone?
Old Jun 12, 2008 | 10:09 PM
rdssk8rcs1's Avatar
no one else before i work on it this weekend?
Old Jun 13, 2008 | 06:37 AM
RedneckRicer's Avatar
ya check the wiring sounds like it could be the issue. you didnt get any debri in the line at all did you when you ran new fuel lines?
Old Jun 13, 2008 | 07:58 AM
rdssk8rcs1's Avatar
Default Re: (RedneckRicer)
Its definitly possible but i doubt it. I switched the injectors around last time i worked on the car to see if it is an injector problem. So i will see if that changed the cylinder running lean tonight.
Old Jun 13, 2008 | 08:08 AM
also what kind of injector wiring are you using? Injector driver or a resistor box? those do fail as well.
Old Jun 13, 2008 | 08:34 AM
rdssk8rcs1's Avatar
a resistor box, yeah i was going to check that as well. Anyone know what the valued resistance should be within the box? Or a valued voltage drop across it?
Old Jun 13, 2008 | 10:44 AM
awdgsx96's Avatar
How did you know you were running lean in the two cylinders? Do you have an EGT in each runner on the mani? Or is this going from speculation on the tune?
Old Jun 13, 2008 | 11:07 AM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">How did you know you were running lean in the two cylinders? Do you have an EGT in each runner on the mani? Or is this going from speculation on the tune?</TD></TR></TABLE>
Thats what I was wondering unless he kept pulling the plugs and checking them out...
cjself14
Apr 28, 2014 05:11 AM
99 eg
Nov 10, 2011 06:00 PM
dkboyny11
Sep 28, 2005 02:39 PM
AllMotorDA9
22
Mar 7, 2005 11:17 AM
91integraLSVTEC
Nov 16, 2003 08:38 AM
