Keeping Cool on long road Trip?!
Old Jun 11, 2008 | 02:31 PM
AK94GSR's Avatar
Default Keeping Cool on long road Trip?!
just wanted to see what some of your guys have into your car to keep it safe while on long road trips with a turbo'd Honda?
i know my car would get hot, but i do live in phoenix so i plan to get a lower temp thermo stat and fan switch.
anyone else have any input on this
Old Jun 11, 2008 | 02:35 PM
chimmike's Avatar
Default Re: Keeping Cool on long road Trip?! (AK94GSR)
just don't tailgate anyone (i.e. so close the airflow to the front is decreased).
You really shouldn't have any problems unless there's something already wrong with the car.
Old Jun 14, 2008 | 11:29 AM
popescuracer's Avatar
drive at night?
Old Jun 14, 2008 | 01:25 PM
ptftw's Avatar
Default Re: (popescuracer)
run water line on the turbo, fan switch is a must,and bigger radiator.
Old Jun 14, 2008 | 01:49 PM
quik sol's Avatar
you shouldnt need to do anything unless your either running a high hp, or have a cooling issue. I have done plenty of 300-350whp hondas with stock cooling system, and a 180 thermostat.....as long as the cooling system and fan functions correctly then you should be good, I would probly upgrade to a fluidyne or a similar product for a 400+whp car, but besides that I wouldnt think of putting a fan switch in the car, your computer will cover your cooling fan on/off time very well.
Old Jun 14, 2008 | 05:37 PM
Tippyman's Avatar
Default Re: (quik sol)
Like stated above, you should be fine if you built it right.
If you're in the summer, to lower your temps, try running distilled water with a bottle of water wetter. No coolant. Don't do it all year though, the water can still freeze and crack your block, and the corrosion protection is very limited when using this much water.
Old Jun 15, 2008 | 08:58 AM
welfarepc's Avatar
if the OP is like me, he is worried about his oil getting too hot and thinning out.
i am going to run an oil cooler in the very near future.
Modified by welfarepc at 12:08 AM 6/16/2008
Old Jun 15, 2008 | 09:04 AM
syzurs1's Avatar
as long as you're not beating the hell out of the car the whole trip it should be fine.
robbys89
Apr 26, 2009 06:26 AM
BrokenRex
Oct 20, 2005 09:17 PM
ATS*Mark
Dec 9, 2003 11:08 PM
B_1_8_hatch
Jan 23, 2003 07:03 PM
