POSSIBLE BAD COIL
Old Jun 16, 2008 | 12:08 PM
gt30rintegra's Avatar
Default POSSIBLE BAD COIL
i checked the wires, plugs, compression test, map sensor, and for all boost leaks.. everything checks out good.. its a 94 integra b16 swap with a gt30r.. 2 days ago my buddy drove my car and when to shift from 3rd to 4th and hit second by accident. it over reved real bad and broke the VSS, but now when ever the car is under load, the boost breaks up.. this is the only other thing i can think of. also checked the turbo, its fine.. if anyone can give any sugg. it would be a lot of help.. thanks everyone
Old Jun 16, 2008 | 12:56 PM
maxaldinger's Avatar
Default Re: POSSIBLE BAD COIL (gt30rintegra)
I would say bent valve but you checked the compression
Old Jun 16, 2008 | 01:36 PM
turbo-crx's Avatar
do a leakdown test to confirm.
Old Jun 16, 2008 | 06:16 PM
Default Re: (turbo-crx)
i checked everything for leaks.. so you don't think its a coil.. because since it happened, its got a shitty idle to it.. and everyone i've talked to said that when honda's over rev, all that power gets back to the distibutor and blows out the coil.. that would explain the bad idle and if the coil wasn't giving enough spark under load it would break up right???, also if i ease into the gas, i can get about 10 pounds out of it before it breaks up, the ecu is set for 17psi and the waste gate is 9.. even running off the waste gate it still does it... thanks
Old Jun 17, 2008 | 07:22 AM
HMTforlife's Avatar
Default Re: (gt30rintegra)
Bump, mine's doing the same thing.
Old Jun 17, 2008 | 03:10 PM
Default Re: (HMTforlife)
yeah.. i ordered a new msd coil for the car.. i know its a long shot but i can't think of anything else.. i'll let you know if it helps anything
Old Jun 17, 2008 | 04:26 PM
steven_highet's Avatar
Buying parts and using that as a way to find a problem can become kinda expensive. As the guys have said,
1) Check your timing (Mechical and with a Timing light) if that all checks out,
2) Compression Check
3) Leakdown Test
If all the above check are fine this will eliminate alot of possiables,
On the coil thing I have never heard that before sounds like some BS.
Have you pulled you plugs?
Old Jun 17, 2008 | 04:36 PM
94TegOwner's Avatar
probably the shitty msd coil. mine failed on my turbo Integra conveniently while i was trying to sell it with only about 5k on the coil. it would break up in boost real bad and had a misfire at idle. i would say go back to stock ignition and see if that fixes it
Old Jun 17, 2008 | 04:44 PM
Boostfed's Avatar
New User
Do you have the stock coil inside the dizzy still? If so then bypass the MSD coil and try that before buying a new one.
A leakdown test is best to check as I think you may have bent a valve or some valves actually
Old Jun 17, 2008 | 06:04 PM
Default Re: (Boostfed.com)
yeah like i've said i've done the leakdown test, checked the plugs and everything.. the coil is stock i'm pretty sure.. i ordered a msd coil... because like i said i heard alot of people saying that it goes like 94teg said.. ha but apparenly msd coils are shitty ha
Old Jun 17, 2008 | 08:47 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt30rintegra &raquo;</TD></TR><TR><TD CLASS="quote">yeah like i've said i've done the leakdown test, checked the plugs and everything.. the coil is stock i'm pretty sure.. i ordered a msd coil... because like i said i heard alot of people saying that it goes like 94teg said.. ha but apparenly msd coils are shitty ha</TD></TR></TABLE>
You stated above that you did a compression test and you checked for leaks, that is not a Leakdown test . You need to use a Leakdown tester with compressed air, it will determine if you have bent valves
Old Jun 18, 2008 | 04:48 AM
oh ok sorry about that.. i was confused. ok well ill do the leakdown test and hopefully its not the valves.. i just don't understand how i can still hit 10psi easing into the gas but not hit 17.. becuase wouldn't the car run shitty if the vlaves where bent.. the car rights fine normally, and when boosted alittle it seems like it had all the power it did before.. it just only does it at full throttle
Modified by gt30rintegra at 6:08 AM 6/18/2008
Old Jun 18, 2008 | 06:46 AM
HMTforlife's Avatar
$20 says your valves are fine.
Old Jun 18, 2008 | 03:43 PM
EASY101's Avatar
* B A N N E D *
why do people let other people drive their cars? that makes no sense to me....thats how **** gets messed up. lol
Old Jun 18, 2008 | 04:57 PM
SD_Lurker's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com &raquo;</TD></TR><TR><TD CLASS="quote">
or bad rings.
Old Jun 18, 2008 | 08:19 PM
Default Re: (SD_Lurker)
dude tell me about it.. i let him take it to his work because he didn't have a car, any other time i would say no, but the one time i do they gotta f*ck **** up
Old Jun 20, 2008 | 09:28 AM
ok put the new coil in today and absolutly nothing changed.. but i think i know what it is now.. the 2 step that i have on the car, i can put it to wahtever rpm, then punch it and the 2step will go.. but since my v.s.s is broken, it always reads at 0 mph.. so when i totally go wot, i think the 2 step goes off... becuase at any other throttle position i can hit boost fine.. any one have any other suggestions??? by the way are the vss's really like 400 bucks??? anywhere i can find one cheaper????
Old Jun 20, 2008 | 10:55 AM
HiProfile's Avatar
Junkyard? Your VSS was used, so why would another used VSS be such a bad idea? You can tell instantly if its bad, and 2-3 used VSS's are far cheaper than a new part.
Also a cheap ebay leakdown tester isn't that expensive. Have your friend buy it for you, and test it out. Either that or have him buy the VSS. In my world, if you break it, you buy it!
Old Jun 20, 2008 | 11:22 AM
Default Re: (HiProfile)
you are completely true man.. and you best believe that he is buying me whatever parts i need.. i want the car back on the road so bad.. thanks alot
Old Jun 20, 2008 | 06:01 PM
ok new update... got a vss outta a junk yard and put in and speedo works, and its back at 17 psi again.. thanks to everyone who helped out!!!!
Old Jun 20, 2008 | 06:31 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gt30rintegra &raquo;</TD></TR><TR><TD CLASS="quote">ok new update... got a vss outta a junk yard and put in and speedo works, and its back at 17 psi again.. thanks to everyone who helped out!!!!</TD></TR></TABLE>
Glad you got it solved! How much did the VSS cost you ?
Old Jun 20, 2008 | 09:50 PM
ha it was 230 at napa auto parts.. but i went to the junk yard and got a used one for 30 bucks..
EKJOE
Jul 14, 2010 06:31 AM
SOHC_MShue
Dec 14, 2006 07:27 AM
DC5ftmfw
Aug 7, 2006 05:43 AM
Doodoo
Aug 15, 2001 04:28 AM
