return line facing foward? where to get barbed fitting?
Old Jun 22, 2008 | 11:13 AM
See Are X's Avatar
Default return line facing foward? where to get barbed fitting?
im replacing my 2.5" downpipe with a 3", and now the new downpipe gets in the way of the return fitting in the oil pan. So now i'm going to have to relocate the fitting closer to the driver side. This is going to make the return line angle slightly towards the front of the car. Is this going to pose a threat?
Also, are B16 oil pans steel or aluminum? Can I get barbed fittings for these at Home Depot or Lowes?
Here's a crappy pic...
Old Jun 22, 2008 | 11:34 AM
Stealthmode Performance's Avatar
Default Re: return line facing foward? where to get barbed fitting? (See Are X)
You may have a difficult time finding a 45 or 90 degree barbed fitting, but the straight ones are available most anywhere in the plumbing section. Having the drain facing any direction isn't going to be a problem as long as you still have a downward slope.
Old Jun 22, 2008 | 06:20 PM
See Are X's Avatar
Default Re: return line facing foward? where to get barbed fitting? (Stealthmode Performance)
when getting on it, the g-force wont push the oil back into the turbo?
Old Jun 22, 2008 | 06:27 PM
OMGWTFBBQ!'s Avatar
Not unless you can accelerate at 3+ Gs like a Formula 1 car.
Old Jun 22, 2008 | 08:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by See Are X &raquo;</TD></TR><TR><TD CLASS="quote">when getting on it, the g-force wont push the oil back into the turbo?</TD></TR></TABLE>
Not unless it's completely parallel with the ground. I've set up turbos on hf manifold/adapter plate setups that leave the drain just about parallel and the only smoking issue we had was going downhill.
Old Jun 22, 2008 | 11:35 PM
jakeiscool's Avatar
Banned
earls or aeroquip.
jacob4lester
Feb 16, 2010 08:36 PM
pjr710
Jan 14, 2010 03:28 PM
WildChild
Sep 15, 2005 08:35 PM
Mr. Softee
Sep 18, 2003 08:09 PM
Trigun
Jun 17, 2002 10:47 AM
